How big is the fuel tank?
Received 3,908 Likes
Shotime92, the tank by definition is only 14 gallons. But, I think that they understate the tank some as I have been able to fit 14.5 gallons into the tank a few times with about a gallon left based on the "miles to empty". But, I wouldn't rely just on the dash telling you that you are good for so many more miles. I have never pushed my car to the point of running out of fuel. So, exactly how much it would take to top off the tank is hard to say. So, in reality, it is probably a 16 gallon tank.
shotime92 (08-04-2013)
showtime, before you get crazy with the tune up, give the rear brakes a once over. In my playing with my car, I have noticed that the rear calipers can stick a little bit and that by using the e-brake a lot, will cause the rear pads to drag even with the e-brake released, resulting in lower fuel mileage. If you want me to go into more detail, let me know. Granted, at 89K miles, you are coming close on needing new plugs and PCV valve, so, that would not hurt either.
Maintenance 7-13
Capacities
US Quarts Litres
Engine oil change including new oil filter. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.1 5.8
The rear axle (final drive unit), transfer box and automatic and manual transmission units
(gearboxes) will not normally require to be checked or topped up.
Cooling system, including reservoir and climate control . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.5 8.0
Windscreen washer reservoir:
– without headlamp powerwash . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
– with headlamp powerwash . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
2.6
6.3
2.5
6.0
US Gallons
Fuel Tank
Total fuel tank capacity . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16.2 Gallons
Indicated refIll capacity – E to F on fuel gauge . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14.9 Gallons
Unindicated (reserve) capacity . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.3 Gallons
hen555
09-07-2015 11:13 PM
deanh
09-06-2015 08:20 PM
