how can i tell if my TC seal is damaged?
Hi i replaced my oilpan (dont recomment anyone attempt this unless theyre experienced mechanics) anyway come to find that i removed the halfshaft and might have damaged the internal seal. What will happen if its damaged? will there be overflow? overheat? i want to keep an eye on it to see if its damaged. thanks
Received 3,909 Likes
Jag-Genius.....
how do the fluids get back and forth? There is a double internal seal around the drive shaft, and an O-ring that is on the outside of the T-case that slides into the tranny. The T-case is sealed off from the tranny.
If the tranny fluid mixed w/ the T-case, then my T-case would not be sitting on my work bench split in half right now!
Ak Jag
Ak Jag
FS[SouthWest]: 19" Aquila Wheels with Tires
jorgef858
01-14-2016 11:32 AM
