How to change the tachometer language?
Hi again!
I have just installed today my new HID kit (thank you to all people advised me ). So, I take off the battery and now, when I reinstall it, I see the tachometer now show info on English (I´m from Spain). Could I change it or a I need visit the Jaguar Retailer?
Thank you for the support.
Regards!
RE: How to change the tachometer language?
The climate, radio, nav and all I control with touchscreen is in Spanish as I can choose it on the touchscreen menu but for the tachometer I have not idea how I can change it again for Spanish as it was before take off the battery. But, OK, if nobody knows I´ll ask the dealer.
Thanks!
Thanks!
I found the solution on the owners guide, I will try it tomorrow:
Display language
To change the display language, switch the ignition ON while pressing the ‘ML/km’ switch. The trip computer will display the current language. Press the ‘ML/km’ switch repeatedly to cycle through the available languages. Once the correct language is selected, press the ‘A/B’ switch. The new language will be selected after a delay of three seconds.
If you wish to exit the language selection function without changing the display language, you can either press the ‘RESET’ switch, wait for 10 seconds or switch the ignition OFF.
Display language
Guy-Pierre Boucher
09-16-2015 05:55 PM
Gerard Radimaker
09-13-2015 10:33 AM
1964Daimler
09-09-2015 11:28 AM
