how do i change my clock
Guest
Posts: n/a
I just bought an 02 x-type 3.0L and have spent days trying to figure out how to change the clock on the radio. I've pushed every combo of buttons and can't find any reset button. Also, the ignition key tumbler seems to lock sometimes and not release the key unless I turn it back and forth a few times. Can anyonehelp?
[/align]
To reset your clock see section 2-3 here:-
http://www.keycast.com/keycast/jagua...TYPE_Audio.pdf
Re the ignition key tumbler try squirting some WD40 on the flap that raises when you insert your key into the ignition barrel,Sometimes this sticks although it might be something else as when the flap sticks it can also cause the horn to sound (UK not sure on USA) when you try and lock the car.
1964Daimler
09-09-2015 11:28 AM
