How do I replace key fob battery (2002 X-Type)
How do I replace the battery in my key fob for a 2002 X-Type? Mine works, but the battery must be weak since the range is limited (~10 feet from the car).
I presume once I get it open I need one or two 3V lithium batteries. Do you know what battery # and how many?
Do I need to reprogram the key fob after replacing the battery? If 'yes', how do I do this?
Thanks.
Thanks.
Received 9,007 Likes
Guest
Posts: n/a
![](http://www.skjagtech.co.uk/images/s-type-x-type-xk8-key-fob-battery/jaguar-flick-key-fob-s-x-xk.jpg)
For those of you that have the Jaguar flip out Ignition/door key and need to know how to change the fob battery here are the instructions
You will need a small crosshead screwdriver, a small flat blade screwdriver, Replacement battery.
This task should ideally be completed within three minutes of removing the circuit board
First remove the key from the Fob by inserting a small flat screwdriver blade into the slot in the fob assembly and push toward the key. Always point the key away from yourself to avoid injury.
![](http://www.skjagtech.co.uk/images/s-type-x-type-xk8-key-fob-battery/fob-battery-change-001.jpg)
![](http://www.skjagtech.co.uk/images/s-type-x-type-xk8-key-fob-battery/fob-battery-change-007.jpg)
Remove the screw from the circuit board and lift the board away avoid touching the components and handle at the edges only. Take care also not to touch any connectors.
![](http://www.skjagtech.co.uk/images/s-type-x-type-xk8-key-fob-battery/fob-battery-change-010.jpg)
![](http://www.skjagtech.co.uk/images/s-type-x-type-xk8-key-fob-battery/fob-battery-change-008.jpg)
Tbone4469 (08-26-2015)
If for some reason you need to re-program your remote after changing the battery, I posted some instructions on a previous thread. Here it is: https://www.jaguarforums.com/forum/s...ghlight=remote
There are also instructions in the FAQ section.
