how do you remove rear view mirror from the base mount?
There is a black plastic cover that pulls off (above and behind the mirror), it is held in place with little tab so working it in a few different directions should unclip it and it will come off.
Once the cover is off you will be able to access the connectors for the rain sensor (going into the rearview mirror "mount") and the dimming/light sensor connector on the rear of the mirror.
With the two electrical connections unplugged, rotate the mirror one direction or the other on the base and gently pull in a downward direction (down in relation to the mirror mount).
The light sensor for the auto headlights is part of the mirror, without that sensor connection the exterior lights simply never come on when the headlight switch is in the Auto position.
4bizonly (12-17-2011)
1) Do you know where that auto headlight sensor is? Maybe on the back of the actual mirror case or on the base somewhere where it connects to the windshield?
You mentioned the two connections plugged into the mirror are for the rain & dimming sensors.
Once the cover is off you will be able to access the connectors for the rain sensor and the dimming/light sensor connector on the rear of the mirror.
With the two electrical connections unplugged...
davidladewig
09-03-2015 06:32 PM
