How to flush and check fluid level Auto Trans
Transmission Fluid Drain and Refill
Raise and support the vehicle
Place a suitable container under the transmission drain plug
Remove the transmission drain plug
Install the transmission drain plug & Tighten to 45 Nm
Lower the vehicle
Remove the automatic transmission fluid charging pipe cap
Use automatic transmission fluid WSS-M2C922-A1 or equivalent meeting Jaguar specification
Fill the automatic transmission with 8 litres of automatic transmission fluid through the automatic transmission fluid charging pipe
Carry out a fluid level check and adjustment
Transmission Fluid Level Check
Make sure J-Gate shift selector is in the Park position
With the engine running and the foot brake applied, move the J-Gate shift selector through ' P-R-N-D-4-3-2' and back to the ' P' position to circulate the automatic transmission fluid until the temperature reaches 30 to 40°C (86 to 104°F)
When the automatic transmission fluid temperature reaches 35°C (95°F) check that the selector lever is in the ' P' position raise the vehicle
With the engine running, remove the automatic transmission fluid level tube plug, Remove and discard the level plug and sealing washer
If the automatic transmission fluid does not come out of the transmission fluid level tube the automatic transmission fluid level is insufficient. If this is the case add the automatic transmission fluid in 0.5 litre units into the automatic transmission fluid charging pipe until the automatic transmission fluid comes out of the automatic transmission fluid level tube
Make sure the automatic transmission fluid temperature does not exceed 40°C (104°F). If the automatic transmission fluid temperature does exceed 40°C (104°F) stop the automatic transmission fluid level check and allow the automatic transmission fluid to cool until the temperature reaches 30 to 40°C (86 to 104°F).
Allow the automatic transmission fluid to come out of the automatic transmission fluid level tube until the overflow stops at a temperature of no more than 40°C (104°F).
If when the automatic transmission fluid level plug is first removed and automatic transmission fluid comes out of the automatic transmission fluid level tube, allow the automatic transmission fluid to come out of the automatic transmission fluid level tube until the overflow stops at a temperature of no more than 40°C (104°F).
Install the transmission fluid level plug, Install a new level plug and sealing washer, Tighten to 15 Nm
Install the automatic transmission fluid charging pipe cap
Lower the vehicle
Lower the vehicle
Lower the vehicle
The following 3 users liked this post by FactoryJaguarTech:
2002xtypejamo2956 (11-27-2019)
There is always a risk when you are out of warranty and using non OEM parts, but I suppose there's no development without trying something new... I just want to give all the best for my cat and I suppose this product could be the one. If there's someone who have tried something else than original product, please tell how did you succeed with it.
Guest
Posts: n/a
2002xtypejamo2956 (05-27-2022)
Whats up guys, I just found this post. I recently had to replace my radiator and in doing so had to remove the inlet and outlet hoses on the intercooler. I guess this is cooled by the tranny fluid...anyway long story short i didnt reconnect the hoses properly and lost A LOT of tranny fluid on the driveway. I was able to find a description of where the fill port is on this forum. However, there were no pictures of where exactly the fill port was. I have attached this picture so it would be easier for everyone to find. Also somebody else in the forum, i can't remember who, made the following suggestion.
Dump the tranny fluid from the drain port and fill it up with new fluid once a quarter. Now your only going to get what is sitting in the transfer case i believe (I'm not an expert) but that should be about 3-4 quarts. If you do this even twice a year it will definitely help an older tranny. Like i said i'm no expert so anyone feel free to jump in. Also i used Castrol Mercon V when i refilled my tranny after dumping everything.
If you cant find the drain port for the tranny fluid then.....well i'll let everyone else jump in. Also it's a hex key for the fill port i believe its a T30.
How did you deal with the whole Temp of the fluid? You know like it was explained in the first post here. Im looking into doing this soon.
