How to flush and check fluid level Auto Trans
I don't know what you're referring to as the "fill plug" in your picture, but I have circled it in yellow for you. If you are referring to anything other than what I circled then you have removed the wrong thing, which is probably why you think it's made of metal.
Also, see my older post in the link I posted above, it has very detailed pictures and was easily accessible through the "stickied" FAQ links.
Gold, I definitely filled the wrong port. However like said earlier i lost about 3-4 quarts in the driveway and the transmission wouldnt engage. I poured the ATF in the spot to the left of the text box that shows what i thought to be the "Transmission fill" and once i got my Jag to temp i cycled through all the gears closed it back up and the car operates perfectly fine. I was definitely a little hesitant at first because i wasn't sure if that was where the tranny fluid went. I was able to my finger in the hole and saw that it was definitely tranny fluid in there so i went for it. Like i said the car operates properly now so do you think i will have problems in the future. I definitely won't reference that picture anymore since im off. But hopefully your new pic will help others.
Jim,
I followed the steps of the above post and drained 4 quarts of transmission fluid and replaced 4 quarts. The problem is that I am now getting a "GEARBOX FAULT" and the car will not start and will not come out of gear.
If you have any answer or suggestions please help!
__________________
__________________
Wolfy
05-28-2024 08:06 AM
