how long to complete a drive cycle - long answer to a short question
Guest
Posts: n/a
painful but this is what it takes to get to DTC P1111 ( all systems go) I drove my car 800 km (8 hours)yesterday on the highway only (not muchcity driving) after erasing all codes, I started with the P1000 and just checked now, still P1000 - waiting for one of the below to be finished before getting a P1111 my code reader shows each test below. For sure the dealer knows all this and they know what drive cycle they are doing. It is just so complicated that they dont explain the whole thing to customers.
FROM JTIS : [font=univers-light][size=1][align=left]The Engine Management and Transmission Control systems are continuously checked during vehicle operation by the Engine Control Module (ECM) and Transmission[/align][align=left]Control Module (TCM) on-board diagnostic (OBD) facilities. Powertrain OBD incorporates six diagnostic monitors. Each monitor has an associated group of DTCs. The[/align][align=left]diagnostic monitors will complete the diagnostic test(s) if a specified service “drive cycle” is carried out.[/align][align=left]The six diagnostic monitors are as follows:[/align][align=left]– Heated Oxygen Sensors Monitor[/align][align=left]– Adaptive Fuel Monitor[/align][align=left]– Misfire Monitor[/align][align=left]– Catalyst Efficiency Monitor[/align][align=left]– Evaporative System Monitor[/align]– Comprehensive Component Monitor (Engine Management / Transmission)
[align=left]DIAGNOSTIC MONITORS DRIVE CYCLES[/align][align=left]Technicians can ensure that an OBD Monitor drive cycle is completed and that all or specific components have been checked by completing a specified drive cycle.[/align][align=left]Use the following service drive cycles to confirm that the components and subsystems covered by the Diagnostic Monitors are operating correctly.[/align][align=left]HEATED OXYGEN SENSORS MONITOR DRIVE CYCLE[/align][align=left]Upstream (Universal) oxygen sensors:[/align][align=left]1 Engine OFF; cooling fans inoperative > 20 seconds.[/align][align=left]2 Start engine and bring to normal operating temperature > 82 °C (180 °F).[/align][align=left]3 Drive the vehicle between 3000 – 4000 rpm at a steady speed. Lift foot completely off accelerator and coast to a stop within 30 seconds. Do not touch accelerator[/align][align=left]pedal for 4 seconds after coming to a stop.[/align][align=left]4 Repeat step 3.[/align][align=left]5 Idle engine for 11 minutes.[/align][align=left]Downstream oxygen sensors:[/align][align=left]1 Start engine and bring to normal operating temperature > 82 °C (180 °F).[/align][align=left]2 Drive the vehicle steadily between 48 – 97 km/h (30 – 60 mph) for 10 minutes.[/align][align=left]3 Drive the vehicle above 3000 rpm in 4th gear at a steady speed. Lift foot completely off accelerator and coast for 30 seconds.[/align][align=left]Oxygen sensor heaters:[/align][align=left]1 Start engine and bring to normal operating temperature > 82 °C (180 °F).[/align][align=left]2 Idle engine for 3 minutes.[/align][align=left]ADAPTIVE FUEL MONITOR DRIVE CYCLE[/align][font=univers-light][size=1][align=left]1 Start engine and bring to normal operating temperature > 82 °C (180 °F).[/align]2 Idle for a minimum of 10 minutes.[align=left]MISFIRE MONITOR DRIVE CYCLE[/align][align=left]1 Record flagged DTC (s) and accompanying WDS DTC Monitor freeze frame(s) data.[/align][align=left]2 Fuel level > 25%.[/align][align=left]3 Start engine and bring to normal operating temperature > 82 °C (180 °F).[/align][align=left]4 Drive vehicle to the recorded freeze frame conditions (from step 1).[/align][align=left]5 Repeat several times.[/align][align=left]Note regarding misfire monitor DTCs:[/align][align=left]If on the first trip, the misfire is severe enough to cause excess exhaust emission, the individual cylinder DTC plus DTC P1316 will be logged. The CHECK ENGINE MIL[/align][align=left]will not be activated. If the fault reoccurs on the second trip, the individual cylinder DTC plus DTC P1316 will be flagged, and the CHECK ENGINE MIL will be activated.[/align][align=left]If on the first trip, the misfire is severe enough to cause catalyst damage (more severe than excess exhaust emission), the CHECK ENGINE MIL will flash while the[/align][align=left]fault is present and the individual cylinder DTC plus DTC P1313 (bank 1), DTC P1314 (bank 2) will be logged. When the fault is no longer present the MIL will be deactivated.[/align][align=left]If the fault reoccurs on the second trip, the CHECK ENGINE MIL will flash while the fault is present and the individual cylinder DTC plus DTC P1313 (bank 1),[/align][align=left]DTC P1314 (bank 2) will be flagged. When the fault is no longer present the CHECK ENGINE MIL will be activated.[/align][align=left]CATALYST EFFICIENCY MONITOR DRIVE CYCLE[/align][font=univers-light][size=1][align=left]1 Start engine and bring to normal operating temperature > 82 °C (180 °F).[/align]2 Drive vehicle steadily between 1700 – 2500 rpm for 5 minutes.[align=left]EVAPORATIVE SYSTEM MONITOR DRIVE CYCLE[/align][font=univers-light][size=1][align=left]1 Ensure that fuel filler cap is fully closed (minimum three clicks).[/align][align=left]2 Fuel level > 30% and < 85%.[/align][align=left]3 Using WDS, perform ECM DTC Clear (even if no DTCs are flagged).[/align][align=left]4 Drive vehicle for a minimum of 2 minutes, and until engine is at normal operating temperature.[/align][align=left]5 Using WDS, ensure that the EVAP Canister Purge Valve is operating by observing “PURGE VAPOR MANAGEMENT VALVE – DUTY CYCLE”. If the valve is not[/align][align=left]active, ECM adaptions have not been learned. Conduct a “green ECM” Drive Cycle as described in Technical Service Bulletin.[/align][align=left]6 Drive vehicle to the road where the EVAP System Drive Cycle will be conducted. Stop vehicle and switch OFF the ignition. Leave ignition OFF for 30 seconds,[/align][align=left]then restart the engine.[/align][align=left]7 Accelerate briskly to 80 km/h (50 mph) ensuring that the engine speed reaches a minimum of 3500 rpm for a minimum of 5 seconds.[/align][align=left]8 (0.040 inch EVAP Test) View WDS “PURGE VAPOR MANAGEMENT VALVE – DUTY CYCLE”, “CANISTER CLOSE VALVE – VAPOR RECOVERY SYSTEM”, and[/align][align=left]FUEL TANK PRESSURE – VAPOR RECOVERY SYSTEM”. Avoiding high engine loads, drive the vehicle steadily between 65 km/h (40 mph) and 100 km/h (60[/align][align=left]mph). Avoid driving conditions that will produce excessive fuel movement. WDS should give an indication that the test is active (it may take up to 30 minutes[/align][align=left]before the test will initialize). When the test has initialized (EVAP Canister Close Valve CLOSED), it will take approximately 90 seconds for the test to complete.[/align][align=left]9 (0.020 inch EVAP Test) Continue driving vehicle as explained in Step 8 for an additional 10 minutes.[/align][align=left]10 Gently coast the vehicle to a stop. Allow the engine to idle for 2 minutes and view WDS “PURGE VAPOR MANAGEMENT VALVE – DUTY CYCLE”, “CANISTER[/align][align=left]CLOSE VALVE – VAPOR RECOVERY SYSTEM”, and FUEL TANK PRESSURE – VAPOR RECOVERY SYSTEM”. WDS should give an indication that the t
Bo,
Thanks for the reply! The dealer completed the cycles. Now the underlying problem is the mdssoftware will not communicate with my car. I took my X to a non Jag mechanic who works on Jags and the hooked up globally to my car and nothing! None of the systems they use can communicate with my car. Now the non Jag tech said that I could have a corrupt down load in my car which only Jag can update. Does that sound like it could be it? Also, my front driverside turn signal they cannot fix. They changed the light bulb and the whole assy. When I talked to the non Jag tech he looked up online a recall of of MitchellOnDemand and said he found a recall regarding the modules not working. Does that sound right? Could it be something else?
Guest
Posts: n/a
My 02 had a recall to replace the module that runs the turnsignal.. ( and many other things) the defect was not very serious, there were times when the bulb was burned out and the dash indicator would work normally. The drive would never know he had a burned out bulb.
I dont think that you specific problem is part of the recall... but if your car is due to be done.... then get it done.. you get a new turn signal module and that may solve your problem
I dont know what your communication issue is. I dont understand why the dealer cant get to the bottom of it. Seems to me that is what they do for a living?
