how many miles on your Xtype?
Old 07-13-2014, 01:21 PM
ArmXT's Avatar
2003, 2.5, Sport, Auto
55,700 miles in total, drove about 16000 miles since bought it two years ago.
replaced the following: Downstream O2 sensor, MAF sensor, oil pan gasket & recently an instrument cluster that goes disco mode after driving for half an hour.
I acknowledge that this car is more than 10 years old already and consider the following fixes minor, well, besides the instrument cluster I suppose, but with winters reaching -4F I'm not surprised at all.
  #402
Old 07-13-2014, 09:46 PM
X-TypeMentality's Avatar
2002 2.5l with 168,013 miles. Runs rather well for being high milage and old age.
  #403
Old 07-14-2014, 05:53 PM
jmsl1956's Avatar
Originally Posted by pu5hkar
just testing the longevity of our cars...
mine has 56000
Just bought our 2002 X type a month ago. It has 182,000 miles on it.
  #404
Old 07-14-2014, 08:10 PM
Diavolo's Avatar
currently 41,298 miles.
2005 X-Type 3.0 Sport Auto
  #405
Old 07-16-2014, 11:41 PM
trugr8ns's Avatar
Cool
2002 3.0 X-Type Sport (Silver), 5 Speed, w NAV. Just drove across country. From Toronto to B.C. And it turned 341,000. Still quite smooth took it to 170 Km/H a few times on the drive. Noisy tires and possibly a bearing. Going to flush fluids this weekend hopefully and oil change. Needs full brake work. Have been quite happy with it during my ownership. We slept together a few times Hard to get a hotel at odd times of the night in smaller towns. LoL! Looking forward to winter although this will be the coldest for this Jag during it's lifetime. Its from East Coast. But spending its first winter in Alberta!
Have to remind myself NOT to drive it like a Japanese car. It's keeps purring like it wants to go faster LoL! I'm learning to cruise in it.
  #406
Old 10-04-2014, 09:39 PM
camwantsajag's Avatar
Smile
I have an 04 xtype 3.0L sport. she has 139209 on her. I bought it last month with 138+++ on the meter. One issue since and that is the lower control arm came loose from the steering Knuckle But Till I die I hope. My summer baby
  #407
Old 10-05-2014, 07:25 AM
UKnFor-dluv-expat's Avatar
Default Got my 2nd x-type!
I love this car. I bought my wife an 02 wit 29k miles about two years ago. Still runs like top! I got into the gold business, and needed a nice ride, she wouldn't let me drive hers, and my Ranger didn't fit the profile. So I found a 2008 x-type with 36 k miles! Took a while to find it, but it was in San Diego! Drove about 9 hours to get it, and it is flawless!
  #408
Old 10-05-2014, 07:43 AM
Lcgi's Avatar
Arrow
I got 132,000 Klms (82,000 Miles) on mine - and running very smooth indeed.
  #409
Old 10-05-2014, 09:04 AM
Chas944's Avatar
172k on my 02 Sport. Always do regular transfer case and trans oil changes ~60k miles with synthetic. Just R&R original H2O pump for a leak and replaced LF steer knuckle due to bearing play. Still runs strong.
  #410
Old 10-06-2014, 11:11 AM
Mr. G's Avatar
I purchased a 2002 with 172k two weeks ago. It has 173k now. This was a private sale with all service receipts for the last 10 years. The car runs like a new car. PO changed the oil with Mobil One every 5k miles and has every receipt if you can believe that. Many major items were done IE: Cooling system, A/C system incl. compressor, belts and tensioners, fuel pump, etc. Amazingly nice care for the money. The only thing I needed to fix was to replace the broken clip for the driver's sun visor.
What did you use for transfer case oil? How about the trans? Is it a manual trans, mine is?
Gregg
  #411
Old 10-06-2014, 03:33 PM
wa3ra's Avatar
135500 miles on a 2002 2.5. Runs very well, and the oil lab says it is barely broken in!
  #412
Old 10-06-2014, 03:47 PM
Five Speed's Avatar
2005 2.5 " Spirit "Limited Edition Auto . Just turned over to 50.000 mile . Just taken it in for annual service £175 , also treated it to a full set of New tyres . ( Marshal Matrack 35's) £304....
  #413
Old 10-08-2014, 04:52 PM
Chas944's Avatar
Gregg
Hi Gregg, yes my Sport is a 5spd manual....I would not have it any other way
For the transmission Redline MT80 (for transmissions) and transfer case I have used Redline 75w-90 and Royal Purple most recently. Both oils seem to work very well. The very 1st time I changed the transfer case oil was after I bought the car used with ~ 67k on it and NOOO Oil came out. I did a fill and flush on the transfer case at that time and did regular oil changes on both. Oil has since came out looking very clean. For engine oil I have used Amsoil in the past but have used Castrol Edge (gold bottle) since it is more regularly available.
  #414
Old 10-09-2014, 08:24 AM
Mr. G's Avatar
Isn't there some kind of viscous coupler in the transfer case? Seems there would have to be considering that the system is full time 4 WD. Normally they require an ATF type of fluid, not gear oil.
I will check on the net to see if I can get a comparison to the Jag specification in the owner's manual
Thanks ..... Gregg
  #415
Old 10-09-2014, 06:57 PM
MeatBag's Avatar
2003 X-type - acquired in 2009 with 35,100 miles, now at 79,800.
I wonder what pu5hkar - who started this thread in July 2008 with 56,000 miles - is up to now.
  #416
Old 10-09-2014, 10:23 PM
Chas944's Avatar
Thanks ..... Gregg
Hi Gregg, I mistyped on the transfer case oil. The transfer case calls for 75w-140 oil. I had used Amsoil SVG 75w-140 in the transfer case and rear end differential originally and 75w-140 Redline and Royal Purple since.
  #417
Old 10-11-2014, 02:18 AM
Mally's Avatar
Default How many Miles
I bought my 2005 Xtype SED Estate in 2009, with 89,000 on the clock. Its now done 257,000 miles. It was used as a taxi for 3 years and now we tour all over europe and spend most of our time in Spain. It has had a lot spent on it, suffering all the common faults on this model, 2 clutches (DMF main faults), Turbo replaced by Jag dealer, £1300, (robbers), later I discovered the Actuator fault from this forum. Wobbly wheels, new drive shafts. New cylinder head due to cracked and broken camshaft lobes. New injectors, pump and fuel rail, due to swarf. But our garage in Spain (Conesa) solved several small problems with bad starting ( Fuel pressure valve) (EGR cleaned out) and a couple more, that were supposed to have been done at our UK garage. It now averages 50 mpg, on long runs and 42 locally, and accelerates better than when I bought it.
  #418
Old 10-11-2014, 08:19 AM
Black 04 Jag's Avatar
Default RE: how many miles on your XtypE?
Just bought mine 2004 Xtype has 38000. Runs and drives like new.
  #419
Old 10-12-2014, 11:15 AM
Celeta Moses's Avatar
1998 XJ8 looks like new - 65K actual
  #420
Old 02-19-2015, 03:09 AM
Admiral Ragecore's Avatar
2003 X-Type 2.5 Auto with 427,000 miles. Only routine maintenance and mostly stop and go Manhattan miles. That's the secret to a healthy X-Type.
Heh....actually we just bought this car and it has 152,324 miles. It's running and driving very nicely, but needs the normal stuff, as the original owner just went by the book.
Quick Reply: how many miles on your Xtype?
