how many miles on your Xtype?
Old 07-28-2017, 12:32 PM
Kaden Cannon's Avatar
My 2004 jaguar X-type has 250,000 miles on it and still runs like the day I got it
  #462
Old 07-29-2017, 03:30 AM
DaveJessop's Avatar
68k when I bought mine in January - now 72k
  #463
Old 07-29-2017, 03:32 AM
Paul_59's Avatar
Banned
  #464
Old 07-29-2017, 03:43 AM
DUNKS's Avatar
  #465
Old 07-29-2017, 05:34 PM
iownme's Avatar
Originally Posted by DUNKS
56,000
201000
running better now than when i got it at 103000
  #466
Old 08-01-2017, 05:41 PM
cooch's Avatar
212000, bought new in 04
  #467
Old 08-02-2017, 02:41 PM
dspguitar's Avatar
Smile 150K + miles on my 2003 x-type
I've got a 2003 X-type 2.5 gasoline.
Just turned over 150K miles on it.
Nothing major to deal with yet. I replaced the radiator, upper water rail (hoses ), thermostat, and belts at approximately 100K.
Just replaced a water pump last week.
My goal is to shoot for 300k+ on this car.
  #468
Old 08-02-2017, 02:44 PM
JonK's Avatar
A good plan to renew the transmission fluid and transfer case oils too soon...
  #469
Old 08-02-2017, 04:26 PM
938001's Avatar
Miles my Blue 02 = 123,000 my White 07 55,600 miles
Chris K PA
  #470
Old 09-29-2017, 09:55 PM
ian20x's Avatar
Just bought it with 130k.
  #471
Old 12-26-2017, 10:18 AM
pclem's Avatar
Smile How many miles on your x-type
I bought my '03 in 2006 with about 43,000 miles. It now has 140,000 and beginning to have electronic issues.
  #472
Old 01-11-2018, 12:24 PM
wa3ra's Avatar
2005 I just picked up is at 67K.
Looks like the 2002's birth certificate is about to be cancelled at 158K, due to rust...although it runs so well, I might just store it and fix it later!
  #473
Old 01-11-2018, 04:05 PM
SolarWinds's Avatar
Not in miles, sorry, but it's at 139 148 km as of today. I bought it at near 120 000 almost two years ago.
I didn't have any electronic or motor issues but I had quite some expenses on suspension and drive components (bushes, arms, hub and wheel bearing).
However it's still a pleasure to drive, especially on long trips.
  #474
Old 01-19-2018, 03:03 AM
Green Machine's Avatar
Default Mileage
2003 2.5l 99,000+ Getting ready to replace plugs in the spring.
  #475
Old 01-19-2018, 03:05 AM
Default Mileage
2003 2.5L 99,000+ Getting ready to replace plug in the spring.
  #476
Old 01-19-2018, 09:25 AM
dwbarry's Avatar
Default Just busted 202,000
I am original owner of 2004 X-type 3.0.
  #477
Old 01-20-2018, 08:36 AM
pclem's Avatar
Default Engine light and ABS light on
Hi Everyone,
Just had the manifold gaskets replaced and in the last two years spent quite a bit on the same engine light on issue. So far, spark plugs were replaced about 20,000 miles ago, hose clamps replaced, fuel injectors cleaned. So far, the light is out. But the brakes and bearings constantly need replacing. The transmission seal was replaced at about 75,000 miles. It's cost more than 4,000 dollars in the last two years. It has 141,000 miles on it now and the mechanic said the ABS module will be 3,000 dollars to replace. I still love the car but I think maybe it's time to say goodbye.
pclem
  #478
Old 01-20-2018, 09:56 PM
sawduster's Avatar
Originally Posted by pclem
Hi Everyone,
pclem
You can send the ABS module to Xemodex for repair for $269. It's plug and play (no programming needed) and it comes with a lifetime warranty.
  #479
Old 01-22-2018, 09:39 AM
chknhwk's Avatar
I just rolled 99k in mine and it's making me sad. I know 100k is right around the corner now...
I have the intermittent ABS failure - not sure if it's the sensor or the driveshaft yet. Passenger rear window is busted, won't go up all the way. I think my windshield wiper fluid froze and broke the reservoir so now the squirters don't work. I have a blown fog light bulb and I ordered the wrong bulbs (I can't work on my car at the condo complex and I don't have anywhere I can rent shop space from so I relied on Sylvania.com, amazon and jagbits.com for my info). My center console doesn't turn on until the car warms up so I have to make sure my heater is turned on high enough I don't freeze in these cold Massachusetts mornings, LOL. All four struts are blown and leaking fluid. I need front upper strut mounts and bump stops all four corners. Hopefully I'll be able to find some space to work on my car soon so I can do plugs and coils this year. I'm working with another forum member to convert my interior over to one without nav and with heated seats. I hate the Akebono pads I put in last year, they are very soft compared to what I like. But all in all I love this car and I would only consider replacing it with a 2017 XE-R Sport in BRG or a Fusion Sport with the twin-turbo V6.
I can't wait to get a wagon and a red manual transmission to go with this one, though. I want a whole fleet.
  #480
Old 02-02-2018, 09:39 PM
JeremyHand's Avatar
2001 3.0 Sport, 223k I just put a new egine with 42k miles and a transmissions with 37k in it. Went all out, new starter, clutch, dual mass flywheel, alternator, radiator, battery, a bunch of sensors, spark plugs, drained the whole car new liquid everywhere. I will get 1 million miles out of this car one way or another.
Quick Reply: how many miles on your Xtype?
