how many miles on your Xtype?
Old 04-02-2009, 01:20 AM
pu5hkar's Avatar
103000 nice!
  #62
Old 04-02-2009, 05:43 PM
Master Deep's Avatar
I have 64,300 miles (80% city/ 20% highway) on my 03 that I picked up new 11/9/02. It's driven extremely hard everyday and it performs beautifully. Only mechanical problem so far was a leaking water pump that was replaced at 60k miles.
  #64
Old 10-20-2009, 05:40 PM
Disco stu55's Avatar
83 000 kilometers, 02, 2.5 l, good lont lating cars, but the occassional problems do arise, u can't prevent that
  #65
Old 10-20-2009, 07:12 PM
BuckMR2's Avatar
Nearly 90000 on my ex X Type and over 106000 on my XJ
  #66
Old 10-20-2009, 07:20 PM
BuckMR2's Avatar
  #67
Old 10-20-2009, 07:55 PM
MRomanik's Avatar
35500 on 07 X Type
  #68
Old 10-20-2009, 10:03 PM
queensnewbie's Avatar
Originally Posted by vineyards4
03 xtype with 180,000 miles. (Knock on wood) I've only had to replace $1400 USD worth of suspension components - everything else is good.
good inspiration!
'03 2.5, just hit 83K miles no major issues yet
  #69
Old 10-20-2009, 11:50 PM
MattSteele's Avatar
27,750 on a 2005 X-Type 3.0
  #70
Old 10-24-2009, 11:23 AM
solidx's Avatar
'03 just hit 82K and going strong - no issues
  #71
Old 10-24-2009, 03:14 PM
Wankel's Avatar
Instead of being proud of having high mileage with no problems, mine is an 02 with only 31k!
  #72
Old 01-07-2010, 10:45 AM
gotti15's Avatar
I just hit 95,000 on my 2002 X 3.0. The only major issues just occured over the past 5 months - I had to replace the following: Oil Pan Gasket, Valve Cover Gasket, Water Pump, & Thermostat. It was very expensive but it was worth it.
  #73
Old 01-07-2010, 04:45 PM
chknhwk's Avatar
103,400 on an '04 3L X.
  #74
Old 01-08-2010, 09:44 PM
X2 Jag's Avatar
02 with 116K
  #75
Old 01-08-2010, 10:47 PM
ahrbruz's Avatar
Default Mileage
2005 X-Type Estate with 24,400 km on the odo.
Cheers,
Bruce
  #76
Old 01-10-2010, 10:44 AM
umbba77's Avatar
03 2.5L manual
99K so far. It's driven every day. Had to replace the rr sway bar bushings, had a problem with the prop shaft (fixed under warranty), an a/c leak (also warranty). Just normal replacement stuff other than that (IMT o-rings/belts/tires/brakes). Going to do rear shocks when it warms up a bit. Also going to do the t/c oil change...
  #77
Old 01-11-2010, 01:05 AM
morales8416's Avatar
2002 3.0 with 109,000 miles still running strong pnly major thing tranny went out at 65,000, miles thank god for extended warrenty.
  #78
Old 01-11-2010, 08:54 AM
TonyX's Avatar
2003 3L auto with 86K miles. Replaced transfer case, prop shaft, rear sway bar bushing, I/P gage cluster, oil pan gasket, rear trailing arm. All done under warranty except transfer case and prop shaft.
  #79
Old 01-11-2010, 09:15 AM
starvinmarvin08's Avatar
Bought my '02 XType 3.0 w/ 86K
Just noticed after fueling this morning that I passed 108K.
Replaced water pump/belts and upper breather hose at 88K.
It's been oil changes and fuel system cleaners every ~4K. Replaced my Bridgestone Potenza RE960AS Pole Position tires at ~100K.
I have been having some problems with the door handles sticking up and my doors won't shut, though I attribute it to the cold weather.
  #80
Old 01-11-2010, 03:41 PM
bbjack's Avatar
05 bought it in Jan-06 with 11k now has 68 k
Quick Reply: how many miles on your Xtype?
