How to remove sunroof shade?
Download the workshop manual pdf.
http://www.mediafire.com/download/xp...Manual.pdf.zip
Look at page 501-05 ( page 2407 of 2810 )
timetraveler1 (06-27-2014)
i Have the same issue in my Jaguar X type, can any one help in this regard. i downloaded the PDF file but unfortunately i didn't find out how to remove the shade alone.
If you can get under the loose fabric, I would try 3M double sided Velcro tape instead
Spray adhesive is an option and if applied correctly won't bleed through the headliner. There are a few keys to it being successful: 1) remove as much of the remains of the foam as possible (I use a vacuum with a brush attachment for the accessible areas and then a gloved hand and small towel for the rest 2) spray the glue on the headliner cardboard only (not the fabric) and allow it to set until it is tacky before pressing the fabric to the headline. This will prevent it for bleeding through, you have to be careful on lighter colors but it still works 3) mask off area you don't want glue, potentially including the fabric, otherwise things can get messy.
Super 77 is a good choice though there are headliner specific spray glues. All this works well for a small area and should last years, it's doing well on the area around the windshield and above the doors on my X-type, but if your whole headline is sagging it's honestly going to be a messy disaster to try and do it in place and you really need to replace it properly. And regarding the sunroof shade, I've never had occasion to mess with it, so I have no idea how much if any of this is applicable, I just didn't want the option of spray adhesive to be dismissed out of hand.
I removed the headliner, but i have no idea how to get the sunshade out to do the same. Would you know if i could remove it through the glass of the sunroof, or if would i have to figure a way of pulling it all the way out. i attempted this- but the curve of the back window doesn’t let me pull the shader all the way through.
kabs3012
09-12-2015 10:40 AM
jagent
09-12-2015 09:10 AM
FS[Western US]: Jaguar xk accessories for sale
jfitzoz
09-07-2015 04:28 AM
