How to take of rear headrests?
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
I dont have the fold down rear seats in the car, and was wondering if there is an easy way to take off the rear headrests without having to take the seats out. I know some clips have to be replaced if the seats are removed, so trying to avoid that. Any input is appreciated.
There is a button on the escutcheon where the rods go into the top of the seat. On one side is a button that you push and on the opposite side is a slot where I use a coin to push in. I suspect that these actions release a captive mechanism that holds the headrest in place. When you do these two actions simultaneously, you will be able to pull the headrest out of the seat. It is a bit awkward to do but can be done. Hope this helps.
Hi , like jj says , with a bit of brute force you can ease the rear headrests out with the seats in situ. Bit tight against the rear window but not too bad , just a case of pressing the release section on the collars that grip the shaft then easing them up while tilting them towards you .
Good luck ,
Mike.
Good luck ,
Mike.
