How would I program a transponder key
The transponder is in the fob, not the key.
Jaguar X Type Information - Program Remote Key Fob
Important Note :-All the fobs that you wish to use Must be paired at the same time. Every time you operate the key as in step 5 above the code will be changed, previously programmed fobs will no longer work unless you pair them all at the same time.
To be very clear = the bottom portion (push buttons, door, etc.) can be programmed to operate any X type by following the programming directions found in this forum. The upper key portion contains the security transponder unit and must be programmed to your specific car by a Jag dealer that has the correct equipment.
Pairing fob =https://www.google.com/url?sa=t&source=web&rct=j&url=https://m.youtube.com/watch%3Fv%3DyJgp7bOGgns&ved=0ahUKEwj6ptTYuuHTAhVO-GMKHQ0XBfYQo7QBCBwwAA&usg=AFQjCNHjs9p1K1Wvl23dSy0c 2wMFCqRLkA&sig2=f4gO0Edxif3pFCJ3pX8pLw
