Hyper Flash Problem
![Cool](https://www.jaguarforums.com/forum/images/icons/icon6.gif)
I installed LEDs for my turn signal lights (front, rear, side) knowing I'd probably have a hyper flash problem. I would have solved it by replacing the flasher relay to be LED-compatible, or would have added a load resister. As it turns out, I have no hyper flash problem on the external lights. I read this is because the flash rate is controlled by the GEM module, not a flasher relay. However, I do have a hyper flash occurring on my interior turn indicators (instrument panel). So without a flasher relay to replace, how do I revert the internal flash rate back to normal??
Mark
Mark
Received 3,906 Likes
