"I didn't know my Jag did that!" thread
#81
#82
So I found a post of "reportedly" how to enable global up for European cars. I tried it for mine and still a no go, although manually using the key by locking, releasing and then holding to lock position again, will now raise windows left open.
Similar to resetting the auto up function. The window buttons have 5 positions = 2+, auto up, 1+, up, 0, neutral, 1-, down, 2+, auto down. Instructions were hold up button in position 1+, to fully close window, wait 2 seconds, release button for 2 seconds, again lift button to 1+ position for 4-5 seconds (but not longer than 6 which automatically cuts out power to preserve motor).
This is SUPPOSED to enable global close on key fob by locking, releasing and then holding lock fob longer than 3 seconds.
#83
So on another "fix-it" site, I found a Jag tech response to this question. It makes no sense to me, but here it is =
He said turn the key on and off 3 times quickly without starting car, it should enable "global" window up. If 3 times does not work, try 4 times.
Personally, this sounds like "voodoo", but here it is anyways.
#84
#85
#87
#88
I believe that on a lot of cars these days, if you look closely at the 'petrol pump' icon in the dashboard display, whatever side the fuel delivery hose sticks out indicates the side of the car that you refuel at.
#89
DUNKS
One of the pathetic features of the car- no key operated manual unlocking.
My old 98 Ford Mondeo Ghia X /Contour had several features that are missing on the X type
I am NOT in trouble as I have a done the five cent fix.
It was one of the first modifications I did when I had read up on the forums about the situation.
So I will agree, most folks would be in trouble.
Owners of US models do not fully escape.
I have read - smash one of the rear lights to get access to the child emergency handle.
One US guy tried this
Details of his efforts.
A search of the UK forum will show a fully detailed step by step method.
My obvious suggestion is do the mod now just in case.
Also if you lose power to the trunk/boot latch when it's closed.
YOU ARE IN ALL SORTS OF TROUBLE.
Especially Brit spec as we don't have the internal strap to open same from inside. "we don't tend to lock our kids in there"
#90
#91
If you hold the lock button on the keyfob with your windows down, it will lock the car and roll the windows up 8)
I think this was only on the 03 or 04+ models though, not completely sure. Or if you just turn the key while it's in the door to make it lock, and hold it for 2 seconds it will roll them up.
#93
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
