i have HID lights, can a non HID assembly work?
hi everyone, i just purchased a jaguar xtype and the driver side headlight assembly is broken. since the car was involve in an accident the headlight is pretty loose from the inside. i have HIDs, the lights work and all when the car is parked, until i drive it and hit those bumpy streets. the light flickers a lot since since its loose, my question is...would a non hid headlight assembly work on my hid lights?? regarding connectors and the positioning of the ballast. thanks
Received 3,887 Likes
djaguar, unfortunately, no, the non-hid headlight assembly is missing an internal ground wire that would prevent the HID ballast from getting power.
The best advice that I can give you is to look on e-bay and there are sellers there that sell the pieces that you need to fix your headlight. It will run you about $60 as I recall to get the new mounts, but once you are done, your headlight assembly will be like new.
I had to fix one of mine, it was a non-HID setup. The process wasn't that bad but separating the lens from the back of the headlight assembly is a huge PITA. I wouldn't recommend baking it as I would be concerned with warping the plastic, but a good hair dryer that can get really hot is a useful tool to loosen the glue.
Check out this kit:
Jaguar x Type x Type Headlamp Headlight Repair Kit Adjuster | eBay
I bought from that seller and was impressed with the quality. These parts are also reinforced with metal and have metal ends unlike the Jag parts which are all brittle plastic.
I opted to buy the set of two in case my other light ever breaks. I would also caution anyone who attempts this to be very careful removing the old part so you don't damage the pieces you need to reuse.
Check out this kit:
bracester (03-26-2013)
Check out this kit:
Check out this kit:
That is awesome didn't know that kit existed! Now I just need to make space in the budget for $50
BrentGardner
28
04-26-2024 03:08 AM
Tony K
03-26-2024 01:53 PM
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
10-19-2015 09:44 PM
rudelover2
09-11-2015 08:53 PM
