I have a p0455 code
Old 12-28-2013, 05:59 PM
nilosjag's Avatar
Default I have a p0455 code
Hi I have a P0455 code Evaporative Emission system leak. I changed the gas cap CODE still there, any ideas of were to look OR what to look for. also get a p1000. Car runs awesome but not sure what to look for anyone out there have any ideas. Need help. 2003 Xtype 2.5 manual shift.
Old 12-28-2013, 06:45 PM
billbjork's Avatar
Bottle cracked(inside pass. fender), hose broke from tank to bottle.Has there been any work done in thoughs areas, or in general that might have damaged something.You can pull off one of the hoses and do a LOW volume pressure test ( 5 lbs or less) and listen for a leak. There is a smoke test that they do but you need special equipment for that.
nilosjag (12-29-2013)
Old 12-28-2013, 08:44 PM
MarkC's Avatar
From JTIS....
* Fuel cap off
* Fuel cap seal defective
* EVAP system leak (canister damage, pipework damage)
* EVAP Canister purge valve to ECM drive circuit: open circuit, short circuit, high resistance
* EVAP Canister purge valve power supply circuit: open circuit, short circuit
* EVAP Canister purge valve to engine purge pipe: restricted, leaking, disconnected
* EVAP Canister purge valve operating vacuum hose leak / restriction
* EVAP Canister purge valve failure
* Fuel tank leak
Old 07-29-2023, 10:13 PM
David Matt's Avatar
Default 2005 Jaguar X-Type X400 3.0L SportWagon EVAP error codes
VIN : SAJWA54A55WE15683
EVAP error codes
How do you fix this problem ?
Permanent P0442 EVAP System Leak Detected - small 0.040 in
Permanent P0456 EVAP System Leak Detected - very small 0.020 in
Permanent P0430 Catalytic Converter System efficiency below threshold - Bank 2
Repairs
Mechanics have ( supposedly ) checked and verified that the Canister is OK.
Mechanics have ( supposedly ) removed the Gas Tank and Replaced ( supposedly ) the Solenoid Valve.
Mechanics have ( supposedly ) checked and Cleaned the Check valve on the throat of the gas Tank and "cleaned" the sealing surface. They claimed that it was "sticky" from "gunk" built up on it.
The Check Engine Light is still on, Steady.
I can NOT put gas in the tank without the pump constantly clicking Off. I can only get 1/4, 1/8, 1/10, 1/20 or 1/100 of a Gallon of gas into the tank at a time. It takes me 20 minutes to fill up with 18 gallons of gas.
Old 07-30-2023, 05:11 PM
h2o2steam's Avatar
Received 1,900 Likes on 755 Posts
When you fill the car and refit the gas cap.....do you wind it until you get it to click three times?
If the cap is not sealing properly, you can get evap errors.
Second thought.....has the fuel tank been opened recently for a fuel pump repair or sender unit replacement?
If the bit "O" rings haven't seated properly you can get a similar effect.
Old 07-30-2023, 05:57 PM
David Matt's Avatar
No, Gas Cap is fine. Looks brand new and I click it more than 3 times.
Like I said, a shop "supposedly" dropped the tank. They said it was "fixed". It's not. They ordered a new Fill Tube w/hose - but then found out ( after my expense ) that the "Check Valve" was in the throat of the tank, not the top of the Filler Tube. They claimed to have cleaned "gunk" off of Seating Rim of the Valve. Thanks.
Old 07-30-2023, 07:15 PM
h2o2steam's Avatar
Sorry, I had a typo in my post.....I meant the big "O" rings that seal the fuel pump access ports.
I recall that another member (Dell) had evap errors he was chasing and eventually found one of the "O" rings hadn't seated correctly giving him a slight leak and evap errors.
Dell Gailey
09-29-2021 07:12 PM
johnpreston84
06-21-2017 03:37 PM
chtp66
05-26-2014 06:45 AM
Jdub
03-26-2014 01:10 PM
Dave S
07-23-2010 06:22 PM
Quick Reply: I have a p0455 code
