I need a new 2003 Xtype catalytic converter:(
Curious, did the Jaguar dealership tell you, if anything else was wrong with car? I heard and thought there were some other posts stating CATs just don't go bad there's a reason behind the failure. Therefore, the root problem should be fixed first, otherwise the new CAT could fall prey to the same problem. Just a thought.
Birdman,
I have replaced 2 of those cats. Easiest that I found was to take it out through the pass side wheel well. you do have to drop the sub frame and remove the rack bolts giving you room to pull out the cat. I also removed the intake for ease of removing the bolts on the header.
Good luck,
The Dr!
Good luck,
The Dr!
Help with used Catalytic converter
Hi, do you still have used cat con for a 2003 Jaguar X type 2.5 ?
Thanks for any help you can provide
Paul Silva
Psilva70@yahoo.com
QUOTE=albackuk;445126]HI Preze
i will have them as of january they are second hand but are removed from cars dismanteled speciically for parts.
Im not sure of the us shipping cost but its certainly not going to be anywhere near dealer prices.
If you need help let me know
alex[/QUOTE]
Paul Silva
Psilva70@yahoo.com
alex[/QUOTE]
bowhunter72 (02-28-2016)
#28
#30
send me a email. Jciamprone@gmail.com
i will see what i can do
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
