I only have 1 Remote/Key, can I program a second?
#41
#42
#43
Guest
Posts: n/a
Hi all from the UK ![Icon Bike](https://www.jaguarforums.com/forum/images/smilies/icon_bike.gif)
I've had the same issue with a X-Type key fob battery replacement; as stated earlier, when you replace the battery you have to follow the series of events shown below. Funnily enough though (although not funny at the time!), the reason for replacement this time was down to the fact I washed my key fob!!!
I was watching TV and all of a sudden my alarm started going off. I went for the keys and they weren't there; and then I instantly realised that the banging from the washing machine earlier wasn't my belt!!! Sure enough, there they were! I had to pull the battery out as the fob kept activating the alarm. I then put the PCB board in the airing cupboard overnight, slept with crossed fingers and next morning, voila, after adhering to the instructions below, the fob worked!!!!!!!! Jag quality!![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
1. Open driver's door.
2. Turn the ignition switch to the "auxiliary" position, then turn the ignition switch to the "ON" position and back to the "auxiliary" position four times. 2002 Jaguar X-Type V6-3.0L - Keyless Entry - Remote Transmitter Pro... Note: A chime from the Generic Electronic Module (GEM) will indicate programming status has been enabled.
3. Turn the ignition switch to "OFF" position. 4. Remove the key from the ignition switch.
5. To program the transmitter, press any key within 10 seconds.
#44
Resurrecting an old thread.
I had two keys when I bought the car new, but lost one of them earlier this year. Now, before buying and programming a new one, I want to make sure the old one is disabled because frankly I have no clue if someone had gotten a hold of it. So how can I disable it? Please don't say dealer.
#45
If you re-program any keys you have now, it will invalidate any other one's that have been programmed in the past. So if you get a new one, program them both together. Here's the skinny....
1.) To program a key fob insert the key and turn to position 1.
2.) Turn the key to position II and back to I (quickly repeat four times) and you will hear a chime if it was done correctly.
3.) Turn the key all the way back and take it out.
4.) Now press any button on ALL the key fobs at the same time to be added and you will hear another chime.
The following 2 users liked this post by JagUR:
02x-typemom (04-06-2012),
ced (01-22-2012)
#46
#47
![Thumbs up](https://www.jaguarforums.com/forum/images/icons/icon14.gif)
1. Insert the key and turn to position I
2. Turn the key to position II and back to position I (quickly repeat four times) and you will hear a chime if it was done correctly.
3. Turn the key all the way back and take it out.
4. Now press any button on the key fobs to be added and you will hear another chime.
5. If you have a set of keys for step (4) you have to press any button on two or more fobs at the same time so they both have the same code or elses one will work and the other won't.
When I read the post I was wondering about spending 200GBP to have my 2 sets re-programmed. I did change the battery as quickly as I could sthg like 1.5 min, but the key did not work after....
I followed the above steps and magic, it works. Thanks a lot for that.
Rgds.
Ced
#49
#50
To summarize,
Step 1: Get some key like this
BRAND NEW UNCUT JAGUAR FLIP KEY FLIPKEY SWITCHBLADE FOB KEYLESS ENTRY REMOTE | eBay
Step 2: Get it cut ( Any recommendation would be great Thanks)
Step 3: Use programming Guidelines provided here to program YOURSELF, you don't need dealer.
Correct?
Correct?
#51
To summarize,
Correct?
Correct?
#52
I did some research about this,
I found this guy online:![Icon Deal](https://www.jaguarforums.com/forum/images/smilies/icon_deal.gif)
Code reading "Tibbe" keys for Jaguar
Keys for Classics, specialists in code-cut keys for classic cars and motorcycles
And his ebay store,
JAGUAR XJ6 XJ12 XJS 1990-96 Tibbe KEY CUT TO YOUR CODE items in Keys4Classics store on eBay!
I have contacted him about me buying uncut keys from eBay, send it to him with pictures of current key. Waiting for his reply.
BUT quick question though, I can program the new key my self through instructions above, right ?
I have done it before when I replaced the battery of the current key. I don't want to spend $200 on this and realize I can't program it.
And his ebay store,
#53
What you have to realise that there are 2 lots of programming on a key. One for the remote fob and one to bypass the PATS ignition.
Anyone can program the remote fob with 1, 2 or 3 keys. This allows the key to open the door but will not start the car.
BUT you can only program a key to start the car yourself if you already have 2 that will start the car.
If you only have 1 key that will start the car then it's a trip to the dealer or an auto locksmith.
#54
I got two keys with my car. One worked the other did not. I considered the
problem to be a flat cell battery - replaced it. Then used the system explained in the posts from you guys. switch between auxiliary and open 4 times (no beep or tone) 5 times still no response. Basically I could not set up my second key. I only hope and pray that the working one lasts me out.
I must say I never expected so much bother - surely there must be a easier way ?
Jzar
09-27-2015 02:55 PM
zdrapec
09-25-2015 05:49 AM
