Idle Issues
2002 Xtype 3.0 Liter
I recently had to replace my Fuel Pump, and I am having some very odd idle issues. Before my fuel pump failed the car would start and Idle High: about 1300 or so but would not go past 5 mph when drying to drive it. Then the pump went out, and had been replaced now it starts again, and it will go past 5 mph but it still idles very high and when first starting kicks up to about 3000 and then lowers down to about 1100, but when driving the car revs up and down at slower speeds and when coming to a stop. I have checked for vaccum links under the hood with carb cleaner, but have yet to find any. I notice the problem is worse going up hill. Any suggestions? Thank You in advance.
Oh one more thing, there is a small port of some sort on the top of the transmission bell housing that does not have any hose connected to it. it's clearly visible from the top of the trunk looking down it's just right of the throttle bottom area. I'll try to get a picture of it to post. I did spray carb cleaner on the port and nothing happen.
Curt
Curt
Curt
Curt
Do a search on youtube for "checking fuel trims with obd2 scanner.
A little googling with put you on the path to understanding what fuel trims are and how to use that info.
Or find the trim values and post them here
curtizb (05-21-2016)
Received 3,910 Likes
Curtizb, just to ask a silly question, have you cleaned the small port in the throttlebody that bypasses the butterfly valve. If that gets some gunk in it, the car then has to use the main throttle valve to control the idle which may lead to the high idle. A little bit of throttlebody cleaner should do the trick to clear out the port.
Not silly at all, I will take all the help I can get and the answer is not I have not. The only thing I have done is shot a little carb cleaner into the main butterfly valve. The car had been sitting for way too long over a year, so I am sure the gas turned to mush since I live in VA and they put Ethanol in the gas which I am told turns to alcohol or even WATER after a long period. Anyway, thanks for the advice. I may just have to take that whole TB off and give it a real cleaning.
Thanks Curt
I have an OBD2 Reader that works with my Android Phone, but it says cannot establish link. Only one person I know of has been able to connect to the computer in this model and he had an 800.00 OBD2 unit with print out. I have tried different auto shops and still not connection to computer.
curtizb, wish you lived a little closer to the VA/MD line. I would tell you to come on over. I live about 40 miles east of Richmond at the southern tip of Maryland.
As for getting the code reader to work. I have the ELM327 unit that works with the Android phone. I have had 2 issues with it and this is how you overcome them.
The easiest one is you need to plug in the ELM unit with the car off. You can then start the car and connect your Android phone to the unit at that point. The reason behind this is you need to establish a time lock with the ECU so you can access the information at the correct time.
The second issue is not being able to establish a bluetooth link between your phone and the ELM unit. First start with wiping from memory any link you have to the OBD unit in your phone. This will help ensure we don't have something else going on here. After starting up the car and getting power to the plug in unit, turn on/ensure on the bluetooth in your phone. Now, tell it to do a scan. It should come up with something to the effect of "pair to OBD". You will want to accept this. It should then ask you for a code. Most of the ELM327 units use the code "1234". Type that into your phone. From there, it should give you a message about the phone being linked to the OBD unit. You can then open up the Torque app and it should connect to the car.
If for some reason it still will not connect, then most likely you have a bad ELM unit. I found mine went bad after a year or so of just leaving it plugged into the car so I could access the data whenever I wanted.
ONe other tidbit of info. There are 2 different versions of the ELM327 unit out there. There are those that work with the CAN Bus system and those that can't. The cheaper ones don't, but that is what you can use on your car. The more expensive ones ($40 vice $20 on ebay) can deal with both styles of vehicles. Jaguar made the change with the electrical "face lift" done in early 2004.
First off thank you guys for being so considerate and sharing you time and knowledge with me and others. The Idle issue has been resolved after much trouble shooting. I'll skip to the fix: I just loosened the TPS and had my Mom sit in the car until the idle came down to 800. Had her pump the gas and whalla! No more idle fluxation! I still have a check engine light on and also got the DSC light for a moment but car is running nicely. I think my next step is to clean out the Throttle Body for good measure and get new plugs. The car had been sitting for two years so it's going to need some tweaking. I'm going to replace all of the TB screws with standard Phillips and not these horrible five point BS screws. Anyway, have similar questions I will be glad to help. Thanks again: You guys ROCK!
Curt
Curt
![Icon Bowrofl](https://www.jaguarforums.com/forum/images/smilies/icon_bowrofl.gif)
