ignition light problem
Guest
Posts: n/a
hi everybody im'e new to the forum so please bare with me.my car is a 2003 2.1 v6 petrol manual converted to lpg gas makes it a lot cheaper to run!
however it has recently developed problem when the car is cold its fine you can run it all day without a fault but once you switch it off the ignition light comes on after the engine has been running for about a minute switch of and restart after 30 seconds the ignition light will go out only to come back on again you have to go through this process for perhaps 30 minutes before the light finally stays out.took it into local auto electricians they said it was overcharging and replaced the alternator(genuine jaguar replacement part) but the problem is still there. any help on this problem would be greatly appreciated .......thanks...................
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
