I'm losing the water pump...
I'm pretty sure I'm losing the water pump in my '02 X-Type, 2.5L. I've been noticing for some time that the heater would not push warm air when the motor was idling (even though the temp guage showed it was wram). I topped the coolant tank with distilled water, and since then, I've noticed intermittently that a puddle accumulates under the left-side front of the motor.
Today I felt around abit, and found moisture at the gasket.
It's possible, I guess, that it's just a gasket problem... but I'm open to other's experiences with this?
117K miles, by the way.
Looks like the Water Pump removal is pretty straightforward.
Any advice / cautions you'd offer?
Any advice about coolant?
What should I pay for parts?
Received 2,193 Likes
Water pump I suppose you know is in the left rear of the motor. It is driven by one of the CAM shafts. When you say left front of "motor". I think of the front as where the serpentine belt is located. The "left" would be my left if I were standing behind the motor, where the transmission is, and facing the serpentine belt. If this is the location you are describing then I'm not sure what gasket you refer to.
Water pumps are EXTREMELY easy on this vehicle. It could be you have AIR trapped in the system and a pocket in the heater core????
I had to replace my pump about 2 years ago. It went out and car over-heated.
Question: After you have driven around for some time 25 to 30 min. and then stop, put in park and allow vehicle to idle. Does the temp guage move up? If it were a weak water pump you should get a rise from the needle.
$75 for the WP is a very good price
Brutal:
I'll take it! I'll send you a PM when I get done here.
And Jfenley: When I say left front, I'm talking (as 'we' always do) as if I were sitting in the cabin. So the water pump sits on the left of the motor, up near the front (of the engine bay). I spotted coolant on top of what I used to call a 'bell-housing', but wouldn't know what to call it on one of todays new-fangled-transverse-mounted-with-the-trans-under/next-to-the-motor-type setups.... :-) (a 'clutch housing' maybe?)
So feeling around, up under the 'snout' of the pump, there's some obvious gasketing going-on there, and coolant coming away on my fingers.
I haven't spent any more time than that, (I was wearing a tie and white sleeves) but I'm fairly confident I found the water pump correctly.
I usually try to lay the bolts out in the same order I take 'em out, so I'm sure they get back in the same way. But it's always nice if you know in advance that this is an issue....
Thanks, Ant....
but no indication whatsoever of over-heating.
none.
zero.
zilch.
nada.
So, now that I've committed to replacing the pump, I'll quite obviously be replacing coolant. It's been a subject I've seen beat to death here.... but since I can't seem to find one signle 'difinitive' answer, or even a consensus.... I'll open it back up.
What coolant should I use?
none.
zero.
zilch.
nada.
While you are replacing your water pump check the idler wheel which provides tension on the belt when adjusted up. These wheels have a sealed bearing which does fail after some time. I replaced mine when the bearing failed and I lost the drive for the water pump... luckily the message centre gave me warning as well as temp gauge and I was able to stop and get the car towed. I've heard of a couple of these go since I did mine... it seems wise to check this out while you are working on that part of the engine anyway.
Mike
Mike
mikiep
12-20-2019 07:37 PM
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
