Immobiliser reset
X-Types suffer from batteries cracking at the earth (negative) terminal and the electrolyte leaks causing corrosion and battery failure. I would inspect the cables and have the battery tested first. If the battery checks good then you will need a scan of the modules to see if the security system has been activated to immobilize the vehicle. The keyfob transmitter should reset the security system.
bob gauff
bob gauff
goges
10-05-2015 04:53 PM
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
2000, alarm, code, doors, immobiliser, immobilizer, imobilizer, jaguar, jaquar, problems, reset, security, system, transmitter, xj8l
