Input on OBD readings
Received 3,887 Likes
Dell, what are you trying to figure out with the data log that you have? Not really sure what to be looking at. Looking at the numbers from just a wide view, I see where your fuel pressure is low which can be a sign of either a plugged fuel filter, fuel pump starting to go bad, or a blockage in the fuel line itself. That was the only abnormality I could see. Granted, not sure what the G(x) and the other matching numbers are supposed to represent.
Yeah, the fuel pump only works on one side. The low fuel light comes on and extinguishes on key on, but does not work with fuel consumption. Learned 3 times the hard way. So when it gets 100-80 miles (range) to empty, I fill up.
Had a P0455 & P0456 & reversed the gas cap seal, cleared & haven't returned. The log was the drive after clearing the codes. I'll attach pics of the "dials" I selected on torque app & got the above info for export.
Dell Gailey (03-15-2018)
AL NZ
02-08-2018 03:58 AM
patrickw813
03-03-2010 08:11 PM
