input shaft bearing replacement?
Does anyone know if you can replace the input shaft bearing or main bearing on a 5spd manual transmission or if you have to replace the entire trans.? Symptom is a bearing noise or rattle at idle but when clutch pedal is depressed the noise is diminished or goes away. I understand this to be a ISB and not the clutch throw out bearing.
04 xtype 2.5 manual trans/90k miles
innzane
09-02-2015 10:08 AM
bad, bearing, change, craigslistohio, input, jaguar, manual, powered, replace, replacement, shaft, throw, transmission, type, vbulletin
