Instrument cluster internal short
Hello guys,
After months of slow investigation of all car module, wiring, instrument panel harness inspection, I have apparently scp internal shortcircuit in instrument cluster (9x43 10849 jc)
I would like to explore options, before going to dealer and him charging me 900eu for new part etc..
I'm thinking of buying used part and save data from old, load to new
Anyone know cheap tool to do that ? Or alternative ?
you just need an instrument cluster and the SDD software, the owners in usa seem to be afraid of using the software. if you dont want to use the software then its an engine ECU same as current one ( auto/manual) the instrument cluster and the transponder out of the key fob, you can also change the GEM module and keep the button part of the key fob. but at least you dont need the new keys saving the change all the locks .
without doing each step and noting the screens I cant provide an exact plan of operation the below is from memory
connect a battery charger to the car so the batt does not get low during the session.
connect the mongoose to odb port and select auto read vin
select diagnostics and then electrical and select instrument not working then recommendations and select program new instruments say yes to warnings and select auto .
make sure you have two keys with transponders ( the bit with the key half not the four buttons
insert first key and follow instructions, then second key following instructions
you will end up with two programed keys the instrument cluster will have one of the following
the real mileage of the car read from the engine ecu
the mileage of the new instrument cluster
altering the mileage of the instrument cluster needs the golden key code, or direct connection the the mcu in the cluster and some special software.
car5car
05-05-2017 09:31 AM
car5car
06-26-2016 05:33 PM
