interesting problem-ideas?
while driving my good running 02 2.5 xtype, I stopped at a red light went to start again and nothing. The motor would rev but very little movement, 10 mph after 1000 feet. Reverse acted the same as drive. I shut the car off and restarted it but the same problem. Seems like a transmission issue, but not sure. Scanner said P1000. The last time I cleared the codes was because of a 02 sensor problem 2 weeks ago. Ideas - suggestions - where to go from here?
Received 3,901 Likes
gozoom (02-15-2016)
Thermo, I think you might but right. I'll bet it's an oil pressure problem, plugged pickup, bad pump, something like that. It certainly had oil dripping from the check plug when I checked. I'll be getting into it in a few days I'll let you know what I find. Thanks all for the input. Really helps to kick some ideas around.
FS[SouthEast]: Transmission & Engine Control Module
HectorM52
06-13-2016 07:30 PM
