ISimple review
ISimple review
After much back and forth debate, I elected to pursue somethng other than the Jag ACM. After much research I elected to go with ISimple's Transit Blu (ISFM22). It's kind of an FM transmitter hybrid. The unit plugs into the antenna input of the radio and communicates via Blue Tooth with the Iphone/Ipod. After pairing your Iphone to ISimple unit, simply tune your radio to a frequency you select as your input source, hit the play on your Iphone, and audio is produced. I've had the unit in place just shy of a week and must say I'm quite pleased with both the peformance and audio quality. I picked up the ISimple on E-Bay for $80.00 and have another $20.00 in antenna adaptors. Installation wasn't much over an hour; one wire to a switched power source (lighter in ashtray), one wire to ground (metal structure around J-Gate), plug into antenna jack of radiio, plug antenna wire into ISimple unit.
Great. I made the mistake and bought a cheap 'no brand' FM Modulator, and had all sorts of problems with background noise. I recently bought a used older ACM. Installed the latest software and have a great sound system.
I also installed an iSimple into my dsighter's Metcury Sable and she is very happy with the results. The Sable's radio is in the trunk so wireing it up was a pain.
bydand
09-28-2015 09:47 AM
bydand
09-27-2015 12:00 PM
