Issue with solenoids
Hello everyone, I have a 2003 xtype that was having shifting problems. So I replaced all of the selinoids but when I put it back together I no longer had reverse. The light on the shifter doesn't even light up. Does anyone have an idea what I did wrong putting this back together?
Steve,
I've moved your question from New Member Area - Intro a MUST to X-Type forum. This is the place to post technical questions about your model as I advised in my reply to your original Intro ( https://www.jaguarforums.com/forum/n...ember-160195/- see post #5 ).
Members here with the same model will be able to help.
steveo2003 (03-30-2016)
https://www.jaguarforums.com/forum/x-type-x400-14/random-transmission-links-158779/
If you took out the whole valve body, iirc there is some special procedure for getting it back in right.
I can't quite remember it because I never did it.
hjt1948
03-05-2016 05:20 PM
