Jag 2000 wheels fit '04 x type. Also tire question
Saw some used wheels off a '2000 jag', that's all the person knows. Got them from cleaning out an apartment basement.
Will they fit an '04 x type? These wheels are 5 bolt, obv...
ALso, my jag has 225/50/17. What is the smallest tire I can use as a replacement? Trying to save some $
Ask for a photo, someone may recognize them.
In a day or two, when I get my PC finished, I can compare the photo with the Jaguar Electronic Parts Catalogue and 95% likely find the name and specs.
All recent Jag wheels are 5 bolt, but some are 5x108 and some 5x120. S-Type and X-Type are the same aside from offset and S-Type wheels being generally wider so you might need spacers with those. XJ and XK wheels are way wider.
Looks like Taurus and X type wheels are the same. 4.25" (measure from 2 lug holes, their bottom to the middle of the hole immediately across the wheel). 108Mm. High positive offset.
I'm going to check my daughter's taurus wheel tomorrow on the Jag and then if it fits, I found 4 taurus wheels with snows...
Received 3,920 Likes
