Jag IMTV o-rings vs LS IMTV o-rings
I personally havnt cross referenced them. Im basing it off another person that claims he did on his swap. And from hands on experience...everything is the exact same. Same size, connector, and everything.
Regardless...its just an o-ring, so if your that worried take one of you IMT to ford and see if it fits while your there. But either way...it will work buddy. No worries.
Here is the post for comparison, about halfway down he shows both. JUST DO IT!!! LOL. Oh and just fyi, they supposedly updated the o-rings to a green color which indicates the color that that made slightly thicker or something, be sure to get those.
https://www.jaguarforums.com/forum/s...ad.php?t=34228
Razkid (12-11-2010)
Well, I got the top IMTV out with no problem and measured the o-rings. The new ones are smaller in diameter overall but the thickness seems about the same so I stretched it to install it and put the IMTV back in place. There is no way to replace the bottom one without removing the intake manifold! The IMTV hits the rise in the valve cover. Luckily I already bought the gaskets and spark plugs just in case I had to remove it. Time to go remove the intake!
clubairth1
29
05-10-2024 12:57 PM
aholbro1
08-05-2021 05:02 AM
