Jag xtype 2003
+1 aspirator fan. It coes on when you open the door andd shuts down about 15 minutes after you exit the car.
Take a close look at the ignition switch. There should be a small door covering the hole where the key inserts. If it sticks open then the electronics will not power down.
You can also take a cell phone on put it on video and shut it inside the trunk and glove box to insure thhe lamps are powering down.
FS[MidWest]: 2003 S-Type R
M. Rockatansky
10-11-2016 12:45 PM
