Jaguar 03 X- Type Battery????
Does a Jaguar NEED a "Jaguar Battery" I was told at a battery store that I NEED a JAGUAR BATTERY!!!
ALSO I Had the Auto club AAA tell me they wont service a Jaguar Battery because they cant get Jaguar batterys!!
MY QUESTION
Is there a Jaguar Battery??? Where do I buy ONE!!!!???????
MY QUESTION
03Jaguar (10-13-2020)
Received 3,887 Likes
03Jaguar, there are only 2 companies in the US that make batteries (Exide and Johnson Controls). So, regardless of what you see on the shelf, you take the same size battery, it came off of 1 of 2 assembly lines. The only differences is a sticker on the outside and the warrantee that the company puts with the battery. There are a few small companies out there that make specialty batteries, but your Jag used a run of the mill battery that has nothing really special about it.
Grab a few batteries and put them side by side. I bet you will find that the plastic case that they sit in will be identical. The tops will be identical. The only difference is the color of stickers on the outside. You see differences, then it was made by the other company. But, you should be able to find a bunch of batteries that look alike there too. If you do some searching under my name, I would say 5 or so years ago, I had a big post that I put out there about who makes what batteries.
Sounds like to me that those companies do not want to deal with high end cars and gave that reason to send you on your merry way.
Paulrwalkington
10-15-2017 12:57 AM
