Jaguar 2.1L SE Petrol Fuel Computer Data Error
Guest
Posts: n/a
Hi All
Thank you all for the help on my last problem (fuel pump burning out and catching alite in the tank).
I have now fitted a new unit but it seems that the fuel gauge wont work now and on the trip computer its says "Fuel Computer Data Error" and the gauge does not move when the car is started.
So far i have tried:
- doing a hard reset by dissconnecting the battery over night and re-connecting in the morning.
- I have tried the old Fuel sender unit outside of the tank (was working fine when removed with faulty pump), no chage.
- I have done a diagnostic search and the only fault codes have come up are P1000 and P1638 which means i need to put the car through its drive cycles, so no relation.
I dont think the sender unit is faulty as its such a simple design therfore it might be a software problem.
Any ideas? is there a way to reset the instrument panel.
Ross
Ross
Received 3,929 Likes
Rossi, what you probably had happen is a wire going to the level gauge is faulty. Is the level gauge failed to "E" or to "F"? If on "E", then you have shorted wiring somewhere. If on "F", then you have an open. This is atleast a starting point for you.
Now, what you will need to do is to access the top of the fuel tank again (I'm sure not the words you wanted to hear, but you probably knew they were coming). Once you have access to the top, you want to find two wires, a black wire and a white/black wire. These two wires are what feed your fuel level sensor. What you will need to do is unplug these wires from the fuel tank and then connect a variable resistor between these two wires (this can also be done with a few set value resistors too). First set the resistor to 160 ohms. With the ignition switch in the RUN position (motor not running), the gas gauge should read full. If you lower the resistor down to 20 ohms, it should read empty. If you set the resistor to 90 ohms, should read about half. If you get all 3 of these readings, then you have confirmed a bad level sensor in the tank, replace the sensor. If you are not getting these readings, then it is a wiring issue between the computer and the tank more than likely. If this is the case, let me know and I will give you more things to look at and we will get you back on the road.
mscontin (01-06-2012)
BrentGardner
28
04-26-2024 03:08 AM
X_Type_South_Africa
12-09-2015 05:37 PM
NinoGrimace
08-26-2015 05:15 AM
