Jaguar Technician Information System (JTIS) download
#182
Since this has been such a great resource over the years for me and it has stayed hosted all this time I wanted to provide a mirror for it as well.Download JCD-1.zip SHASum for JCD-1.zip: 84ff34c5a5521a7bc5760e6624c45b728a285e84
If anyone needs help hosting or wants to provide Jag related files let me know.
Well I was looking for the JEPC, whops but will leave this hosted as well.
#183
Dear Webmaster - I just spent time typing a lengthy narrative of my experience getting JTIS to completely function including the outdated program help files on a Windows 10 machine. Apparently, because of inactivity, I got booted (signed out) so when I went to hit post - well, it all went away. Maybe I'll attempt to tell this another day but for now---just frustrated that the website would do this.
Charlie
Charlie
#184
Charbinjr
I have a lot of experience writing the procedures to install JTIS software.
I found that it is easier to use MS Word to create the installation procedures with all the required text & photos needed and then use Word "Save As" PDF for file option.
Then you have all the procedures in a PDF file format that you copy all the text and images to your post or just insert the PDF file in your post.
here is some text that I copied from my PDF file and put in this post:
Overcoming the problems with installing JTIS (32 bit software application
#185
#186
I do not have any windows 10 or windows 8.1 or windows 8 PCs to any tests on the installation on these current windows operating system.
Your instructions be a great help.
Please include all the necessary steps to successfully install the JTIS software in windows 10.
Jim Lombardi
Jim Lombardi
#187
Hi
Just downloaded the whole lot..but is part 1 missing from both discs?
Best
Frank
Best
Frank
I don't believe it will install on Vista or Windows 7. It needs XP to function properly. Maybe XP Mode on Win7?
I found a new link for the files:
http://www.mediafire.com/?sharekey=0...6b94653a3044fd
IXLLER8 (06-27-2017)
#190
Hi Tinsletown
What part of the JTIS do you mean that did not work?
Need to know more information about where the problem might be.
Is it downloading the files (part1.exe, part2.rar, part3.rar) or putting the 3 files into the same folder - or getting some kind error code when running part1.exe
Did you follow all the steps in the JTIS21 install PDF file?
What windows operating system are you trying to install the JTIS21 software?
#191
Hello, the program downloaded and installed perfectly. When I run the program in comes up but as soon as i try to do anything the application says "JJTIS MFC applications has stopped working" and closes. It just says a problem has caused the program to stop working.
I first installed in on windows 10 64 bit, had troubles, made a post and got directed to your thread about how to install the DAO file, which now I don't think was my problem. I did that, no changes.
I then created a second partition with windows 8.1 32 bit and it does the exact same thing. As important as this manual is to me I then wiped my hard drive and install only windows 8.1 32 bit and it still does the exact same thing.
I downloaded it a couple different times from a couple different sites and to no avail still not working. I downloaded the all the manuals from one site, just the xj8 file from one site so you can see how i am pretty stumped
#193
Yes, that error message is caused by not installing the do350.dll file successfully.
I have seen this issue before.
Looks like you have not registered the dao350.dll.
I purposely skipped registering the dao350.dll to see what would happen.
I ran the setup.exe in the jtis21 folder and rebooted the PC.
When the PC finished the restart, I ran the JTIS shortcut. When I tried the Service menu for model selection I had the following results:
there were no models listed and there was this popup error message
"JJTISMFC Applicaion has stopped working"
"A problem caused the program to stop working correctly"
"Windows will close the program and notify you if a solution is available."
Norri (03-25-2018)
#194
I start looking for stuff, and it's like fixing a virus, so much useless outdated junk about JTIS.
Was there ever a definitive fix for windows 10 pro? If so, is there a link that can direct me to this.
#195
#196
Yeah, I got one, so that's it. I remember when autocad first came out. It had competition from generic cadd. Generic cad was 50 bucks cheaper. I got that one. Then after about 5 years, autocad bought out generic cad to kill it off. We used it until the driver technology exceeded the software capability.
BrentGardner
28
04-26-2024 03:08 AM
Robert1968
06-24-2017 11:16 AM
