Jaguar Technician Information System (JTIS) download
#81
After many fruitless attempts at downloading JTIS, I tried HappyPlumber's link with the download them all on firefox and got it to download, but now I can't get it to run. I clicked on "disk 1" and doubleclicked "setup" but nothing happened. Any ideas?
I gotta get this manual to figure out how to change the coolant temp sensor on my 2002 X type. (I don't even know where the temp sensor is!)
Thanks!
Thanks!
#82
#83
#84
Guest
Posts: n/a
THIS PROGRAM DOES NOT RUN ON VISTA.
IT WILL NOT WORK ON VISTA MACHINES.
YOU MUST RUN IT ON COMPUTERS STILL USING XP
#85
hi merv. ive downloaded this application and im running it on my new hp vista premium. there are a few things one needs to do when instaling but it does work. ive writen step by step by step instructions but its afew pages long, so im not sure if its to long to post. as long as your downloaded file is 470,279KB it will work. you must however remove the tick from the odbc direct file when instaling. then once instaled, you may need to download and instal WINDOWS HELP FILE 6.0-KB917607-x86.msu to get the help program within jtis to work, but i assure you it does work
#88
Here are another set of links:
http://rapidshare.com/files/269347085/JTIS.part1.rar
http://rapidshare.com/files/269357698/JTIS.part2.rar
http://rapidshare.com/files/269359871/JTIS.part3.rar
They might not be that fast for non-premium users though, but more links are always good to have.
#90
It is just zipped (or actually RARed, so you would need WinRAR or equivalent) The site it is hosted on requires a small wait period for free users (I'm a premium user) and somewhat limits the download speed, but it is another option.
#91
Looking at the file creation dates and sizes I have the same version from a different source. I'm running on Vista home premium no problem. I Ran setup as Administrator but don't see why this would have any effect. Maybe you need to run a new version of Acrobat Reader http://acrobat.pdf-master.com/?s=go-...FWNM5QodUENZNQ just an idea.
On XP 32bit it works perfectly. Be sure to run the dao35 installer after the main program installer.
#95
#96
Received 3,895 Likes
MRomanik, if you can find a version that has the 03+ schematics on it, that should give you some good information. May not have all the bells and whistles, but it will cover most of them. The motors and suspension are pretty much unchanged since the start of the X-Type, so, you will be good there. Most of what you may run into problems with is the electrical stuff (schematics not 100% accurate). So, if you can get your hands on a JTIS CD, it should take good care of you. The big thing is figuring out where things are hidden on the CD. Once you figure that out, tons of information there.
#99
Guest
Posts: n/a
Hi
I'm getting an error message (Another application is currently using DAO files. Close all other application. Continue?) when trying to install the dao35 as is asked in the setup file and I'm not running any other programs. Anyone has any suggestions on how to fix it or go around it.
thanks
thanks
#100
Any of these manuals work for the XF's?
Found most of what's posted here working on cannell. Interested in downloading the Mitchell Jaguar information system for most models 1983- if it contains any info useful for the XF. I don't want to burden the host site with an unneccesary download. Thanks.
http://www.cannell.co.uk/Jaguar_Workshop_Manuals/
