Jaguar Technician Information System (JTIS) download
Old 01-16-2010, 04:10 PM
blackcat's Avatar
I have xp2, Is there only this one 470... file to be loaded or do I have to load any other? I also think if I have done something in wrong sequence but let's see what I can do.
  #122
Old 01-16-2010, 11:30 PM
H20boy's Avatar
Received 1,151 Likes on 753 Posts
The JTIS downloads that supersport linked worked great, I could not load it from my computer as a virtual machine, but once I 'burned' the disc, then installed the program everything worked great. If you don't need the XJS repair manual, skip Disc 2 and all the other .rar files with it, and only download the Disc 1 files.
  #124
Old 02-06-2010, 03:43 PM
H20boy's Avatar
thanks for the tip Bob!
  #125
Old 02-20-2010, 06:00 AM
lah024's Avatar
Thanks great post, I had just purchsed this on e-bay for $10
  #126
Old 02-24-2010, 01:54 PM
Mafioso's Avatar
What is the size of JCD-1? for some reason WinRAR will not uinpack these files I keep getting an error, Size mismatch unexpected end of file.
  #127
Old 02-24-2010, 04:37 PM
H20boy's Avatar
Try the exe file then, don't worry about unzipping.
  #128
Old 03-01-2010, 02:48 AM
redbarongraphic's Avatar
i had download and install JTIS but there art empty spaces?
  #129
Old 03-01-2010, 01:14 PM
H20boy's Avatar
Not sure what you're asking red. Can you restate your question?
  #130
Old 03-21-2010, 03:07 AM
H20boy's Avatar
I found an ebayer selling the 2005 JTIS, and its cheaper and less wait than the first UK seller.
If you want the 2004 XJ and some additional features over the earlier versions, I highly recommend this disc.
  #131
Old 03-22-2010, 01:05 PM
_Belial's Avatar
Just saying thanks to the original poster, just got my jag a few days ago so this will no doubt prove an invaluable resource. Thanks.
  #132
Old 09-06-2010, 09:12 PM
scottatl's Avatar
Can post #123 be highlighted or brought to the front of the thread somehow. If I read it sooner it would have saved me so much time using JTIS.
  #133
Old 01-21-2011, 02:56 PM
mrmef's Avatar
+1 for 122 & 123 posts to be included in page 1
  #134
Old 01-30-2011, 12:56 PM
stefan063's Avatar
What is JAG using now instead JTIS? Or there is newest JTIS that covers XF/XJ 2010/11 models?
  #135
Old 01-30-2011, 01:32 PM
BuckMR2's Avatar
The last JTIS was in 2005 (v21)
Since then dealers and public use a subscription only online system called Jaguar GTR (now called TOPIx) to access info for models including all the latest ones
If you go to this site http://www.ownerinfo.jaguar.com/extf...prod/index.jsp (handy for free online owners manuals etc) and click VIEW TECHNICAL INFORMATION at the top it will take you to the site.
  #136
Old 01-31-2011, 10:44 AM
KDW4Him's Avatar
I was a little disappointed after logging in & entering my VIN only to find the listed powertrain introduction document for my 2005 X is from 2001. I was hoping to see the newer style TC information there. The doc listed for my '05 is JJM181517-15 X-Type Powertrain Introduction.
  #137
Old 02-04-2011, 07:31 PM
mcduvall's Avatar
I downloaded this program and installed it, I have XP SP3. When I open it an try to do something, it brings up the window where I will select model and year for about a second and crashes. Also when I try to install: JCD-1\dao35\DISK1\SETUP.EXE it give me an error "The Parameter is incorrect." Does anybody have any ideas?
  #138
Old 02-05-2011, 12:33 AM
H20boy's Avatar
and running it with the CD still in the drive? Unless you install it in a very special way to the hard drive, you must run the program with the disc available. If that fails, try installing it again.
  #139
Old 03-18-2011, 04:20 PM
bobinaz123's Avatar
I have a 98 XK8 convertible with a problem. I have schematics but I need information about the operation of the Body Processor Module control of the convertible top. The last time I raised the top the rear side windows did not come up. The top did come up and latch but the sequence stopped at that point. Now the top will not go back down and the windows are open. I've checked all related fuses and relays. If I press the top up button nothing happens and no relays actuate. If I press the top down button the down relays for the windows actuate but do nothing since the windows are down. I tried to manually open the top following the procedures in the owners manual but it will not go down. In unlatch it withe the allen wrench and goes up an inch or so and no further. If I knew more about the Body Processor Module it might help to isolate the problem further.
Also, are there any diagrams for removing various panels to gain access to some of the components in the schematics?
Bob in Arizona
  #140
Old 03-19-2011, 03:05 PM
mcduvall's Avatar
What files inside of the "J-CD1" folder do I burn to a CD?
Quick Reply: Jaguar Technician Information System (JTIS) download
