Jaguar X Type 3.0 Oxygen Sensors
Hi all,
Ongoing project of my X Type 3.0 Estate. I've changed all the gaskets for the upper and lower inlet manifold, IML's, breather hose (all the usual suspects in terms of seals failing/aging and letting in air) and also spark plugs and ignition coils with a noticeable difference in smoothness and responsiveness in the engine. However, fuel economy with a good 70/30 motorway/in town mileage is barely 20mpg although previously with the same mileage mix I've hit late 20's. And also sometimes when I start up the car it dies if I don't press the accelerator and even so is very lumpy for about 10secs before evening out, a couple of times a week.
Given they're 20yrs old and I tend to replace what I think could be a problem or potential problem (yes more money that sense clearly!) I'd like to change all of the 4 sensors. However, I'm baulking at spending £100 plus per sensor on the OEM Denso's which as I understand it are;
Upstream; Denso 234-9029
Downstream; Denso 234-4798
Does anyone have a good experience with alternate, good quality OE's that are more in the region of £50-£60? there seem to be plenty on Ebay but real life experience of them would be appreciated with links or part manufacturer/number please.
It's a bit confusing in terms of Jaguar part number but again as I understand it they're;
Upstream; C2S51801
Downstream; C2S38497
Is that right? Replacing them seems relatively straight forward if you can wrangle the access and they're not melted in (fingers crossed!)
Thanks in advance for any responses.
Upstream; C2S51801
They can't be the problem you say at start up as they're not used till (say) 30 secs so the engine/exhaust have warmed a bit.
When you have poor MPG on e.g. motorway why not monitor fuel trims? But first check it's running CL (closed loop) as it ignores the O2s if not and "guesses" (approximates) fuelling.
Also check all OBD monitors are happy. (Pending code) P1111 says so; P1000 says not. If P1000 find which monitors are unhappy!
You could have a dirty MAF (so fuelling can't be calculated properly) or some such.
lilmountain (06-24-2024)
Do you either have a complete idiot's guide for what I'm actually looking at/for or another thread that explains it in very simple terms. The way you've written your helpful response I'm interpreting it as it has to be live connected whilst driving and I assume get someone to film the OBDII scanner on the fuel trim bits? Sorry stupid questions! I'm fairly handy on a DIY level but have never gotten into anything other than reading and erasing codes in terms of code readers..
The following 2 users liked this post by Dell Gailey:
JagV8 (06-25-2024),
lilmountain (06-25-2024)
lilmountain (06-30-2024)
I looked up your LR V2.0 manual, it looks like you just drive the car with the scan tool connected then when you stop you select "Review and Report" from the main menu. The user manual is pretty light on info so there may be more to it than that but the device is capable of logging data without resorting to filming the screen while driving. Good luck!
The following 2 users liked this post by Blues boy:
JagV8 (06-26-2024),
Luckily I went Denso in the end and only changed the upstream ones. Bit steep but now they're changed. Weirdly one at the front was the absolute nightmare for me, my hands are wrecked such a tight squeeze, rear one was fairly easy and luckily for me neither were rotted or rusted in. I've noticed an instant improvement in smoothness (car used to have a slight hesitation on acceleration especially from standing start) and I'm checking the fuel economy on a full tank of petrol as of yesterday. If I get 25 mpg or more with mixed driving then I'll be happy!
I've changed vacuum pipe that goes from manifold to throttle body, brake booster vacuum pipe. Breather hose looks ok but replacing with silicon anyway next week. Sorry repeating myself also all other inlet manifold seals changed including IMT, also soaked the MAF in cleaner. There's one other vacuum pipe see photo (the one from just behind air filter hose to firewall) that I haven't changed. Anyone know the name/part number and whether it's prone to failure? Any other know weak points as the symptom i.e. cutting out suggests an air leak? If I don't get anywhere else with this may invest in a new MAF...
![](https://cimg6.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1500x2000/jag_vacuum_pipe_1ee57aecb39df381ace227f22915df0b4bbf6c73.jpg)
Do you mean the brake booster line there, the one with the inline check valve? That is Jag p/n C2S17552. Inexpensive aftermarket parts are available, .
Mine was broken on arrival, previous owner had patched it with RTV. I broke it again myself, it is very brittle.
lilmountain (07-01-2024)
lilmountain (07-19-2024)
mountian, been fighting similar battles with both of my estate / wagon projects so feel you on this. One other thing to check is the vacuum line that runs under the intake to the Fuel Pressure Sensor. It connects to the back of the intake below the brake booster port and runs to the fuel rail at the center. The boots on either end tend to split in ways that aren't immediately obvious. Also the very thin vacuum line inside the plastic cover can easily split if not handled gently. Be aware that the end on the sensor is permanent and can break if you pull too hard. If you break it, the intake has to come off again to get to it. If this is leaking it can cause a slight vacuum drop as well.
also agree with everyone above concerning the 02 sensors. All four need to be the Denso pieces. I've tried Bosch (almost as expensive), part store branded options and the cheap ebay versions. The car hated the Bosch (codes, miserable running), woudn't run on the part store ones and burned up the ebay specials in a few thousand miles. Given the pain of triple installs and cost to "get a deal" the Denso price premium seems cheap now.
As to monitoring fuel trims and O2 operation, the torque app and an inexpensive bluetooth module is the easiest I've found. You can also log with it. The "gauges" are easy to add to the main screen and should show most everything you need.
fmwinandy
07-08-2017 12:28 AM
Suzanne Randeria
11-30-2015 06:24 PM
