Jaguar X-type alignment?
Hey everyone,
I have been noticing that my steering wheel i have to turn it to the left to go strait, do you think i should have my alignment done? I do like in Chicago IL so i do hit a lot of potholes in it, since the roads are like swiss cheese lol. Low profile tires are not meant for Chicago roads. If you think i should have it done, how much do you think it will cost?
Hello,
Yes, it appears the alignment is off but it's best to check it on a newly paved patch of highway (if you can find one...) since older or side roads are starting to heave because of frost. The ruts and pitch in the road are magnified once the ground freezes.
A reputable tire or alignment shop will check it and give you before and after printouts. Unfortunately, the only adjustment on the front is toe-in. Expect to pay $90 for a four wheel track alignment at a national chain, more at an alignment shop.
Good luck,
Steve
Good luck,
Steve
If you have to turn it like that to get it to track straight you definitely need something. Could be an alignment only, but check that the rims aren't bent and have the suspension checked as well. Does the steering wheel shake in your hand when driving or does the wheel just pull to the left when you let go of it? Depending what the ultimate cause is and how long you have been dealing with it check the wera of the tires as well.
So you're saying that you had new tires put on several months ago, when it was warm out (and warm in the tire shop)?
And you're also saying that the dealer took your money, so you're sure that they did everything that you imagined they would? You don't think they might just look at your obviously new tires and realize that they can't sell you a set of tires, so they're not going to bother with your tires any further?
Please realize that tire pressures naturally go down in the cold weather, sometimes by quite a lot. (It's not cold in Chicago this time of year, is it?) A lower tire pressure in one tire would cause the car to pull to that side.
Check your tire pressures. It won't cost you anything, and it may save you from being robbed at the dealer or at an alignment shop.
X_Type_South_Africa
12-09-2015 05:37 PM
