jaguar x-type bushings?
Received 3,887 Likes
XKR, which bushings are you talking about? There's a lot of different bushings in the car and some are integrated into the various parts and others are stand alone pieces. If you can provide a little more information, I will do what I can to give you as specific information as possible. A company that I have had good luck with is "Energy Suspension". They carry a large variety of poly bushings for many different applications.
XKR, this is a very loaded question. THings like say the rear control arms, the bushings are manufactured with the arm. So, in order to install new bushings, you need to buy a new arm. Installing an arm is easy (about a 30 minute job), but expect to pay $110 for the arm and then a $90 4 wheel alignment. But, then you have the buhsings on the sway bars which run $30, take about 20 minutes to install, and that is it.
You start looking at the bushings on say the lower front control arms, now you are talking much higher prices. So, once you know which bushings, we can give you a much more detailed explaination of what needs to be done.
Fraser Mitchell
10-01-2015 04:06 AM
