Hi guys I'm in need of a gearbox oil change (long story why) but I need it done and I need to know what gear box oil does my jaguar x type x 400 2003 2.5 v6 AWD automatic take?
A Mechanic friend of mine suggested I use ATF dexron 3 fully synthetic
Will the oil in the pic below work ?
Thanks in advance
Thank you I did I'm new and found it hard to navigate according to what I found on this site : the jaguar part no for gear fluid is C2S12120 and it is also known as
Justin, go to the top of this page and you'll see a bar: Thread Tools and next to it: Search This Forum. Put a search request in that one for:
Castrol's Transmax FULL SYNTHETIC vs. IMPORT contradicting recommendations
Read the posts. This will be a start for you. I t gets deeper, but almost any fluid with the designation IDEMITSU 17 will probably do the job. You will find other views that will contradict other member's posts, so make up your own mind.
