Jaguar X type interior aspirator/sensor replacement
Hi,
May I get some advice on how to remove the aspirator/sensor behind a small grille on a 2003 2.5 AWD Jaguar X type? Part number C2S13944. It is currently loud. I tried cleaning it through the hole behind the grille with no effect. I bought a replacement, but currently cannot change it because there is not enough space under the steering wheel, after removing the plastic and metal covers, to reach it. Any advice on how to reach it would be much appreciated.
Many thanks
Many thanks
Update: I managed to reach the sensor through the opening below the steering wheel, close to the pedals.
The issue appears to be not the sensor motor itself, as detaching it from the housing the buzzing sound disappears (even though the sensor is functional, running).
The housing itself does not provide a good insulation to absorb the vibrations. I replaced the housing by removing the two screws. The existent housing had some foam around which had a lot of wear. However, the new housing, which had a new foam, when placed, did not provide any difference to the buzzing sound.
One solution is to simply tape the motor somewhere inside the dash, letting it hand in the air a bit, which removes the buzzing sound. Not ideal, but works.
jaguarroger
11-12-2013 12:25 PM
