Jaguar X-Type radiator funs are not running. They however start turning when i switch
Received 3,915 Likes
Africa, with the X-Type, the fans will not run unless called for. The fans will be called for whenever the engine temperature gets too high (above 205F or 97C) or the A/C is called for (which is also happening when the defroster is used). As for the speed that the fans will run is also based on a few variables. When it comes to the engine temp, the more above 205F you get, the faster the fans will spin. Same thing with the A/C. If you have it on a low demand, the fans will spin at a slower speed and may even turn on and off. Where, if you ask for maximum cooling, the fans will immediately go to fast speed and not turn off.
richard toulouse
01-21-2013 08:10 AM
johnxtampa
11-29-2009 10:29 AM
