Jaguar Xtype for sale in Pa 101k
Check out Kelley Blue Book - New & Used Car Price Values. Blue book is about $2,800.00. 5 no way unless real good maintenance records and zero defects.
What the heck. What else do you drive for 4k that may or may not have problems? I say go for it. Change all your fluids after you buy it so you have a baseline and then enjoy the heck out of it. My only advice is to get it up to 60 on your test drive. You should hear a slight hum from the drivetrain that goes away when you let off the gas but if it is an annoyingly louder hum , then you may consider offering a bit less. If the hum is there at say 30 mph regardless of hitting the gas or not then definitely pass. The first is probably just a normal driveshaft bearing noise and the second issue is probably the transfer case. At the end of the day if it seems to be a good solid car and it makes you feel good to be in it then drop the money and own that sucker. Good luck!
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
10-19-2015 09:44 PM
PinnacleWax
Detailing / Car care
08-26-2015 11:44 AM
WTT[MidAtlantic]: Mina performance S-Type Intake for sale
mkrion
08-26-2015 11:43 AM
