jerking and shuddering engine ahfter speed80
Is there a check engine light on? If so, could you maybe be in limp mode that maybe around the 80KM mark the engine RPM is about 3K? At that RPM is when the engine performance would be restricted.
Does the issue always happen at that same speed or could it be when the RPMS get around 3K? If it is the former definitely start with the fuel filter. If it is the latter you would have a code(s) associated with the check engine light. Then have the codes read and report what they are here and that would definitely help with teh diagnosis.
