Just installed HID's in my fog lights - SWEEET!
#101
RE: Just installed HID's in my fog lights - SWEEET!
Hey well I found someone that knows what he is doing and used to be a mechanic and said he will charge me $50 for both the fog lights and the low beam and Im prob just gonna do that. As soon as its done on Saturday ill try and post some pictures of the car.
#102
Yeah you won't pass inspection unless you hide it perhaps...I've heard that others won't change the lights because of inspection...you could always just pull out the low beams and install stocks for inspection....
You get the kit yet jason?
Lastly 50 bucks is worth having someone else do it! As long as that is all he's going to charge you!
#103
Guest
Posts: n/a
I wasn't getting any power to the wire. I was kinda in a hurry and didn't have time to trace it back to see exactly what is wrong. I'll take it to a electrical shop and have them look at it as soon as I get some time. The problem is the ol' lady doesn't want to drive my work truck even though it's brand new while I take it to have it fixed and she doesn't want to rent a car for the day...go figure.
#108
ORIGINAL: jasonzimbran
Yeah IM Fing pissed cause that guy never showed up oh well Ill try and do them this week.
#109
Don't worry i started it late and had no problems finishing...the passenger side (supposed to be the worse side) took me 15 minutes if that to put everything together. I did the drivers side first! Of course he didn't show up you were only paying him 50 bucks! At least do the headlights and do the others after! It really isn't hard like we've been telling you this whole time!
#110
I agree that the passenger side was definately the worst. It took me about a half hour to get it installed, and another half hour to get it functional. The driver side was a breeze. Took out the battery and was done in 10 mins.
It was definately an experience. Now if I had a garage and could have changed my own clutch and transfer case...
#111
Yeah lol I hear you on the transfer case and clutch! BTW how much was the tc? Jason when you do it just take out both covers from the back of the headlamps and than take them in your house or whatever and drill the holes...than if you haven't already remove the battery and move the box enough to help you get at the lamp easily (you don't have to remove it all the way though...) and than do the drivers side. After the drivers side and you know what you've got to do and than do the passengers side....telling you it will only take 15 mins to do the other side once the holes are cut and all...
#112
#116
Bulb type is H1, same as the headlights. I'm in the process of doing HIDs in my fogs. Well..actually, I've already installed them, I'm just waiting on a replacement ballast, as one of mine was bad upon delivery. I'll have pics and a full write up done by next week, assuming the ballast gets here by Saturday...
Preview:
Preview:
#117
Does the front bumber cover and plastic headlamp covers have to come off to get to the "city" bulbs in the high beam light fixture? I put in a new set of H1 high beams 4200K standard wattage with no real improvement. I had gotten the LED replacement from frickinbright.com and could not get the connector off for the city lights from the back.
#118
The bumper doesn't have to come off for any work relating to the headlights, except for removal of the headlight housing itself. All bulbs can be removed from the back of the housings, inside the engine bay. The city lights fit very tightly into their hole into the back of the housings. They require a good amount of force to get out, but do'nt yank them. Just apply smooth firm pressure, and they should pop out. Be extra careful putting them back in, otherwise you'll end up having a real bad day.
I'm not sure what you mean about the "4200k standard wattage bulbs" in the high beams. Most people don't upgrade the bulbs in their high beams because they're so rarely on.
I've actually ordered some various white 194 sized LED bulbs from frickinbrite.com/v-leds.com, so I'm anxious to get them in and see how they look.
#119
#120
The supposed color is equal to a 4200K light spectrum which my new high beam H1's give off. They are a more pure white than the stock Orsam H1 bulbs that were in there but they still are not as impressive as I am looking for.
I am not sure if using a 80w or 100w bulbs in the high beams will overload the wiring or not? I had a Painless Wiring H4 relay wire kit for my old car and I used Narvaor Hella 80/100w bulbs in Cibie E-code 7" round lamps and they were fantastic especially for high beam range.
It may be that the DOT high beam lamps in the X-type arejust not focused enough to replicate that kind of beam pattern despite throwing in higher wattage bulbs. I chose the standard 55w H1 bulbs because I did not want to over load the stock wiring or circuit.
I am real happy with the HID low beams though.
IfI do get the city lights out I will put some silicone grease or spray around the fixture so that they will be less of PIA to get out again.
Thanks for the help!
