Just put in an exhaust.. but have a question!
I had a magnaflow exhaust with some custom tips put in... it sounds amazing..
The only questions I have are...
1. I have the option to cut out the secondary muffler and just straight pipe it through.. which will make it a little louder...
or
2. Chop the whole thing and have an X-pipe fabricated instead of the Y pipe that goes over the axles right now....
or I can leave it as is...
Anyone have any suggestions?
or
RE: Just put in an exhaust.. but have a question!
I'd say chop it all out including the cats then go with 2 straight pipes all the
way back to the two mufflers! Then sell the O2 sensors on Ebay!
OK, I know that won't work guess I'm still living 1987 technology that
would let you get away with that!
Option one would be fine and I doubt cutting out the resonator would
cause a need to reprogram the computer.
Chris
Chris
Received 3,905 Likes
Rosemont, if you are looking for the most power from out of the exhaust system, then the X-pipe arrangement will be the best. I would not recommend going over about dual 1.75" pipes though. Like was mentioned, making too free flowing of an exhaust system will hurt your low end torque. If I remember right, the factory piping is a single 2" pipe (possibly a 2.25" pipe). Going with the dual 1.75" pipes, you will get a freer flowing exhaust (which will help with the higher RPM power) without having a negative effect on the low end torque.
If you have more questions, let me know. I would need to know the series muffler (70, 50, 44, 40, etc) that you are running and the size pipe that you are considering. Then I will look at my car and see what the factory piping size is and go from there. Keep in mind that going with a muffler with a lower series number in it will also minimize the backpressure of the exhaust system, therefore the low end torque.
I do have to admit, the 3.0L engine in my car needs a bit of help above about 5,500 RPM. It seems to fall a little flat and doesn't have the pull like it does below 5,500 RPM. An upgrade in the exhaust system would help with that.
Chris "Thermo" Coleman
What model magnaflows did you go with? I would too opt for the X-pipe configuration. In most V-config engines this will help increase torque and is a smoother flow than a H-pipe. I am not sure what the mad obsession car makers have with 3 and 4 mufflers. If the optimal mufflers were chosen to begin with the added cost and weight of yet another muffler would not need to occur. I for one want to hear my car before being forced into a hybrid.
