K&N Air filter $50 - Is it worth it?
Old 03-11-2008, 08:31 PM
ruslan35's Avatar
Default K&N Air filter $50 - Is it worth it?
I am thinking about purchasing K&N air filter for my X-type, but i wanted to see anyone had done so? Any feedback?
Also, what are the benefits of better air flow? How does it effect fuel economy?
Thanks everyone.
Old 03-11-2008, 09:57 PM
Dennis's Avatar
ud
Default RE: K&N Air filter $50 - Is it worth it?
I honestly don't check the mileage or did I do a before and aftercomparison But I have the K&N and I think it works well..My intake tube is never lined with oil or soot..it is squeaky clean..So anyways, I know I'm getting optimum airflow...I did chisel out the baffling in the filter box to free up the air flow more..
Old 03-11-2008, 10:16 PM
tarheel72's Avatar
why $50? I see them everywhere for $37.50. I think that is MSRP.
Old 03-11-2008, 11:13 PM
Dennis's Avatar
ud
Also, most all of Patrick's sponsors, if any that carries the K&N, will give us JagForums members at least a10% discount.
Old 03-12-2008, 08:28 AM
I think you'd have to be a bit crazy to actually think your getting a performance upgrade by simply changing a filter. I'd only buy the K&N if you are looking for a quality filter not because you are looking for performance gain.
The benefits of having increased airflow really only show when your traveling constantly at high speeds at high rpm's. The factory X-Type airbox is very restricted but is completely sufficient unless you intend on running it at a consistent 130(+)mph on a track. This type of driving is where you would benefit from using an aftermarket set-up with increased airflow.
If you driving at these speeds then I would say it is essential to replace the factory airbox as your engine will not get enough airflow with the stock set-up. Though, if your just using your car as a daily commuter and rarely see 100+mph then you do not need a high airflow system as it will likely just trigger CEL and CNA errors.
Old 03-12-2008, 09:43 AM
ancientsanskrit's Avatar
Ehhh quality, I'm not so much in agreement. Studies have proven that oem paper filters have better filtration than K&Ns and other open elements.
For me it's worth the price b/c I don't have to replace filters every time (I'm lazy). However, factor about $10 for the recharge kit.
As for performance, the contour forums have proven very negligible gains on the 2.5L. In fact some people lost power! Look up 'heat soak' a very common issue on open elements on upgrading your intake.
Old 03-12-2008, 11:00 AM
ruslan35's Avatar
I wasnt looking for performance, but rather wanted a better air flow, which i heard is good :-)
I looked into my intake manifold and it was somewhat dirty with some oil inside. I figured good air filter should help and i dont have to worry about changing it again.
Old 03-12-2008, 01:03 PM
Dennis's Avatar
ud
You do have to clean them every 10,000 to 20,000 miles depending on how dusty your area of driving is..the trick is, re-oiling them properly and not to over oil..
Old 03-12-2008, 01:08 PM
I've talked about the notion of doing an intake manifold cleaning. This is very common a la cleaners dumped into the vacuum ports. I personally do hand cleaning i.e. tearing the upper and lower intake manifold off. I've done it on a few 2.5Ls and a 3.0L Duratec. I've noticed considerable gas mileage increases, better idling and power restoration (psychological, as I don't have any dyno proof).
I'm hoping to do wires/plugs tune-up this summer on the Jag, and will take an extensive look at using the same method for UIM/LIM cleaning. I'll probably throw a post about it.
I haven't had a chance to touch the car except for oil changes due to this stupid winter sticking around for so long.
Sorry just re-read your post. You said oil. You sure it wasn't soot? Oil kind of throws a red flag at me.
Old 03-12-2008, 01:24 PM
Increased airflow is what results in performance gain. You are not going to notice the increased airflow with a K&N regardless of what they advertise. You are simply changing a filter so unless your current one is dirty or you need a brand name on your filter you won't notice a difference and you might as well save your $50.
Old 03-12-2008, 02:05 PM
Dennis's Avatar
ud
We get the idea Arden..you don't like K&N..fine..
Once you pay $50.00 for the K&N you're done...using a OEM filter at $25.00 each you will go through maybe $200.00 or more in the life of the car...That in it's self, is enough justification for a K&N.
For the record, I have a new OEM filter and a K&N to test and I can see a little improvement in responsiveness with the K&N over the paper filter....And my intake tube is clean as a whistle.
Old 03-12-2008, 02:17 PM
I have nothing against K&N. I am simply saying that it is merely a filter change so there's not going to be any significant increase in airflow that would make it worth buying in that respect.
Assuming you bought a new car, Jaguar will change these filters routinely so from my experience with the factory airbox I have never had to purchase an OEM filter.
Old 03-12-2008, 02:24 PM
Dennis's Avatar
ud
That is very true...I don't mean to argue..It's just that there is some miss information On both sides about K&N and they have an unfair rap..Every race car owner I know, ALL run with K&N for better performance.
Anyways..[sm=icon_cheers.gif]
Old 03-12-2008, 03:20 PM
ruslan35's Avatar
Here is my intake to all of you air-intake buffs! Does this look right? I dont know if it is oil, but ona paper towel it sure looks like it.As far as i know, it was never cleaned.
Old 03-12-2008, 05:11 PM
Dennis's Avatar
ud
Sucking oil from somewhere..that is for sure..
Old 03-12-2008, 07:49 PM
ruslan35's Avatar
OK.. i guess a total clean up is due.
Old 03-12-2008, 08:32 PM
Received 9,010 Likes on 4,113 Posts
Size:  6.3 KBName:  X6JYMSAAB5.jpg
Size:  6.1 KBName:  AudiX6JYM-2.jpg
Hey ruslan..........re the K&N filter
Seen many posts about this over a long period of time and mostly everyone seems to agree that there is little / no performance increase from these filters, which you can buy off Ebay I believe for around the $37 btw.
You will save on costs against paper filters but as stated will have to clean it out and re oil etc every 10,000 - 20,000 miles depending on conditions.
Jim
Old 03-12-2008, 08:38 PM
ruslan35's Avatar
Thanks Jim.
Do you guys know how to re-oil intake manifold after i take it off and clean in out?
Thanks all.
Old 03-12-2008, 09:23 PM
Dennis's Avatar
ud
ORIGINAL: ruslan35
Thanks Jim.
Thanks all.
I could be wrong..But I don't think the intake manifold should have any oil in it.
Quick Reply: K&N Air filter $50 - Is it worth it?
